ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   OIL COOLER ????? (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/oil-cooler-4092/)
Monkeyboy Oct 31, 2002 06:12 AM
OIL COOLER ?????
ok now i got my new olicooler hoses installed they work perfectly!no oli dripping! By the way thanks again for the advice about buying oilcooler hoses from a hydraulic hoose manufactuer they seem much more reliable than the original hooses!!
But now its the damn oilcooler its leaking again! Does anybody have experince with the use of olicoolers from other cars? Because its pretty hard to find an original oilcooler from a 280zx here in Denmark! Maybe a cooler form a Saab or Volvo ??
Bleach Oct 31, 2002 08:48 AM
Re: OIL COOLER ?????
I think even a generic oil cooler would work fine. Automatic transmisison oil coolers will work for cooling engine oil too. don't buy one used though, you want a new one so there is only one kind of oil in it from the start.
http://www.zipcon.net/bleach/pages/zcar/zlogo.jpg
Monkeyboy Nov 4, 2002 07:06 PM
ok thanks Bleachzee ! but you think its such a big problem not knowing which oil that has been used? Iīmean isnīt enough just cleaning it as much as possible ? that little amount of unknown oil shouldnīt make a big difference or what? A generic oil cooler is pretty expensive (in denmark anyway!!) I hope to find a cooler from a another car but which?
Dan
speedricer05 Nov 4, 2002 09:10 PM
i have an 83' 280zxt...so, monkeyboy, i'm pretty interested in some of your posts...where do you put the oil cooler (where do you run the lines to)? is there a website that explains the install? and how much does it help?
yo2001 Nov 4, 2002 09:37 PM
Well, make sure the oil cooler is not going to drop your oil pressure level to unexceptable level. I got a homemade one on mine. 5.0 block adapter, a relocation oil filter, 300psi 1/2in hose, and 3 pass oil cooler. And I forgot, I use the turbo auto oil pump.
