nos
Old Sep 8, 2002 | 12:38 AM
auxilary's Avatar
the Dude
Re: nos
i tried letting some NOS into the cabin, and it worked. I started seeing colors, then I fell asleep
Old Sep 8, 2002 | 12:32 PM
lifegrddude's Avatar
Externally Wastegated
Re: nos
Yes, you can nitrous Datsun cars. Make sure to do a compression test.
82ZXT
Old Sep 10, 2002 | 08:23 AM
Re: nos
Well, to answer the question, yes NOS works on Datsun cars.
NOS has a better effect and can be used in greater supply on larger displacement motors. So the 2.8L 6 is probalby the best engine to use it on. You can drill out the intake manifold if you want port injection, or inject it right behind the throttle body. The large aluminum intake manifold is easy to tap into. Most of the 2.8L engines are using fuel injection.
There is an aftermarket intake manifold that adapts a single Holly 4-barrel to run all 6-cyldiners. I have seen a NOS setup put onto an engine like that.
This L6 is in a Datsun truck, and they use a 75hp shot.
Old Sep 10, 2002 | 09:49 AM
auxilary's Avatar
the Dude
Re: nos
do you guys realize that NOS is a company, not the actual item? Nitrous Oxide Systems is NOS. Using nitrous oxide on your car is more appropriate, otherwise I can have NOS by just putting a sticker on it.
and this post shouldn't exist in a technical forum - it's blatantly stupid
