NEED HELP!! (kind of long)
Old Mar 5, 2002 | 03:54 PM
zguy36's Avatar
Dead
Re: NEED HELP!! (kind of long)
If your trannys are truly seizing up, then replace your pilot bearing. That is the bearing that is in the end of the crankshaft that the pilot shaft of the tranny slides into. If that is bad, then the pilot shaft is free to move up and down and will wipe out a tranny quick. Hope that helps ya.
-jeremy-
Old Mar 7, 2002 | 05:08 PM
lifegrddude's Avatar
Externally Wastegated
I don't know if the throw out bearing and pilot bushing are the same thing, but if your car is making a chirping/tweeting sound while the car is just sitting in neutral idling, it could be bad. It prevented my clutch from disengaging all the way and made my car stall plenty o' times. It was on my '71 510.
(your throw out bearing could be bad is what I meant)
82 ZXT
<P ID="edit"><FONT class="small"><EM>Edited by lifegrddude on 03/07/02 09:36 PM.</EM></FONT></P>
Old Mar 8, 2002 | 06:23 AM
zguy36's Avatar
Dead
The pilot and the throw out bearing are totally different things. I believe that on the Z cars, that the pilot bearing is just a brass bushing. Some cars use ball or needle bearings though. If they go bad, then trannys go bad like nothing else.
-jeremy-
81SacUti280zx
Mar 7, 2012 07:19 PM
FubarI33t
Sep 17, 2006 07:57 PM
duowing
Oct 26, 2005 09:42 PM
phrozen209
34
Jan 21, 2005 10:24 AM
lil_racer_tony
Aug 2, 2002 01:23 AM
