need help!
hey guys, my 260Z 2+2 diff center has died on me, and I need to know if a diff from a 280ZX will fit in there. will it bolt in there or do I need to modify anything? if there is anyone who knows about this PLEASE help me, becuase the Z is my daily driver, and Im near crippled without a ride.
Kolts Perth - Western Australia |
Re: need help!
Any of you Australian guys able to help this person ?
I am not familiar with the Australian version of the 260 2 + 2. Mike |
Re: need help!
Do you know if it's a R200 or R180?
The 260Z & 280ZX had both these diffs in them attached is a photo of each. There shouldn't be any issues with using a 280ZX R180 & there won't be any issues with using the R200. The only parts you will have to swap are the output stub axles & possibly the input yoke. Note that the R200 is much wider than the R180, The R180 in the middle is a 240Z unit - note the bolt-in output stubs, the R180 on the right is an R30 skyline unit - it has clip-in 1/2 shafts (CV). The R200 also uses the clip-in system, and can support CV or uni 1/2 shafts. Also note that the R180 has bolt-on aluminium side plates, the R200 uses internal bearing caps. Ben Adelaide Sth Australia IZCC#1902 240Z L31ETT L28ET MR30 Skyline FJ20ET DR30 Skyline RS-X |
Re: need help!
lemme try the file thing again - it was too big....
Ben Adelaide Sth Australia IZCC#1902 240Z L31ETT L28ET MR30 Skyline FJ20ET DR30 Skyline RS-X 17343-diffs.jpg |
Re: need help!
Ben, thanks for the info man. looks like my diff is a R200. I;ll have it pulled out next week, and first see if it can be refurbished.
Are the R31 skyline diffs similar to the ones used on the 260Z, someone told me they were R180. Kolts Perth - Western Australia |
Re: need help!
The Japanese HR31 GTS(X)(R) have R200 LSD's, HR31 Passages have R200's. The Aussie R31's have a Bang... ummm, Borg Warner live-axle & the Silhouette's have a cone-type LSD fitted.
Re: need help!
rebuilding the rear diff might be wind up costing a lot more than just picking up a unit from a junkyard. I think I paid $50 US for my r200 in good shape (i pulled it partially apart to find out it's been recently rebuilt) with halfshafts and moustache bar.
If it's going to be rebuilt, perhaps you may as well look into putting a cheapie LSD in there. See Phantom Grip |
Re: need help!
Ben do you know how much a R200 LSD is worth here in AUs as I understand we didn't get them? Did they units come on the 300zx turbo's? I'm talking in aus by the way.
Thanks. Gavin, Melbourne Australia 73' Datsun 240z |
