mods to your z?
Old Oct 18, 2002 | 11:31 PM
Creator's Avatar
Re: mods to your z?
yeh i got a 260z, street cam, high compression (about 9.9:1) stock heads, 6-3-1 Header, SU Carbs, and a 1980 close ratio 5speed, 3:90 gears in the rear, and it goes way faster then my pop's 330CI BMW (and mines 30years older heh).
Old Oct 20, 2002 | 03:05 PM
auxilary's Avatar
the Dude
Re: mods to your z?
plop in a small block chevy
'73 240z
'99 neon R/T
Old Oct 20, 2002 | 03:30 PM
auxilary's Avatar
the Dude
Re: mods to your z?
for their time, they were pretty quick, and fairly advanced. independent rear, aluminum head, overhead cam (yes, i know that pushrods were invented after overhead cam design - ford raced wtih DOHC setup in the 20s). They were a cheaper alternative to a camaro/mustang genre and featured stylish almost ferrari like looks.
and bi pli tires didn't help
'73 240z
'99 neon R/T
Old Oct 21, 2002 | 08:15 AM
Re: mods to your z?
Ok, during the middle of the 70's, the horsepower ratings that Nissan claimed changed. At first they were telling you the engine's horsepower (crank power) and then from 1979 on they stated the wheels horsepower.
The 240Z has 150hp at the crank. Speaking of crank power, the 260Z has I think 142hp, 280Z has 170hp, 280ZX from 1981-83 would have 180hp, and the turbo is about 210hp.
Now, the engine used in the 280Z and ZX from 1975-80 has 135hp at the wheels. Compared to about 130hp at the wheels for the 240Z. The 81-83 280ZX changed to flat top pistons and got another 10hp for 145hp at the wheels. The turbo model put down about 180-185hp at the wheels. But also, all these cars produced torque in the 160-170 lbs range at only 3500rpm.
The turbo model's torque is above 200lbs.
That means that even though it might seem that your straight six only has the same horsepower as a late model Civic, you have so much more torque kick in really quick and you'll be off the line out in front right away. With every shift you're still within the engine's good power RPM range so you can accelerate quickly. My Altima has good power at high rpm, but when it shifts it slows way down and has to climb back up the rpms again to get that 150hp again. I think it has only 130lbs of torque at 5000rpm though! And that's a 2.4L 4-cylinder.
Old Oct 21, 2002 | 03:48 PM
Creator's Avatar
Re: mods to your z?
actually the plate on my 260z's engine bay says 165hp, (crank).
.cre
Old Oct 22, 2002 | 08:34 AM
Re: mods to your z?
Ok, so 165hp for the 260Z, sorry.
I know that the wheel horsepower went down from the 240Z to the 260Z for some reason. I heard it was the carbs. Anyhoo, that's just a general timeline. Some of the numbers might be off a little.
Yet, i've heard of people with a modifed 280ZX turbo go to a dyno and get 160hp at the wheels. So, sometimes you think your car is running perfect but its not. Little tweaks here and there can suddently boost your power and make better use out of your bolt-on modifications. It has happened to me!
Old Oct 22, 2002 | 08:46 AM
Spudz's Avatar
Re: mods to your z?
I have heard the same from people who think they have tons of HP,
and then get it on a dyno only to be dissappointed with the numbers.
I try not to say I have " X " amount of HP and can run " X" in the 1/4
unless I can back it up with data. One reason these HP or 1/4 time
threads end up going nowwhere.
Old Oct 22, 2002 | 08:57 AM
Re: mods to your z?
Ok, so I'll jump in and make a claim that I can not totally back up. I have dynoed my car, but have made some tweaks since then.
I've got the stock L28 with F54 head. Flat top pistons, round port exhaust. 180psi compression accross all six cylinders! (like a new engine) and its got 201,000 miles. I'm running a K&N cone filter, big throttle, hot coil, headers, 2.5 exhaust through a glasspack and chambered Flowmaster. I've got the stock 3.9 rear gear. I get about 150-155hp at the wheels and 170lbs of torque at about 3400 rpm.
Old Oct 22, 2002 | 10:03 AM
lifegrddude's Avatar
Externally Wastegated
Re: mods to your z?
I've posted my dyno sheet on my profile for those who care to see it. I'm thinking my exhaust manifold leak that has come back is the reason. I fixed it once (a big pain!), and now it's back... Gotta be reason for it. It's in the same spot too... #5&6 cylinder area. When I get some more time and stuff, I'm going to fix it again, dyno the car and hopefully post some more respectable numbers. BTW the turbo is still at stock boost, I think it spikes due to the internal wastegate (they suck), so that's when the popoff valve went off. Talk about a big hp loss, man it was like hitting a rhino, the car just stopped pulling!
82ZXT
71 510 autocross & 71 510 daily driver
Old Oct 22, 2002 | 11:13 AM
Re: mods to your z?
Because they don't start reading untill about 2500rpm. What you do is get going slowly on the dyno. Then when you reach 4th gear, you get it to about 2000 and tell them to start recording. At that point you floor it and let the engine run to whatever peak rpm you wish.
When I had a bad distributor and too much fuel pressure, my dyno was actually 135hp and 166lbs of torque. Replacing my distributor brought my engine back to life. Also, replacing my fuel pressure regulator let me pass emissions and get better milage.
Old Oct 22, 2002 | 11:19 AM
auxilary's Avatar
the Dude
Re: mods to your z?
actually the civic si (99-00) puts down over 130 to the wheels. the '02 model puts down about that + about 20ft lbs more torque, because it's a 2 liter motor instead of a 1.6
'73 240z
'99 neon R/T
Old Oct 22, 2002 | 11:26 AM
Re: mods to your z?
Ya, and their usual peak horsepower is right around redline at 6500 rpm or so... and their peak torque is around 4500-5500 rpm. Which means below that rpm they are running under 100 horsepower and torque... but they usually come with some pretty low 1st and 2nd gears.
Compare that to the torque and horsepower that the 350Z puts out! I'd like to see an actual dyno result with one of those. I would not be surprised if they actually lay down less than the claimed 287hp.
Old Oct 22, 2002 | 11:41 AM
Spudz's Avatar
Re: mods to your z?
I agree Bleach ! You have to realize the source of the information
on factory dyno results. The factory is going to have their best tuners
in there and make sure they have a good healthy motor for the test.
I figure they are going to be around 250 - 260 HP. When people tested
the Maxima they noticed a bit lower numbers then the factory.
I read the story of Pontiac sending a tuner GTO to be tested for one
of the magazines. They put a 421 in it with some mods instead of
the factory 389. Those HP and torque numbers shure do help sells.
stealth300Z
Mar 29, 2003 09:22 PM
4rdhater
Nov 22, 2002 04:53 PM
SoonToHave1
Jul 22, 2002 10:13 AM
rick84
Jun 13, 2002 10:37 AM
Z_For_Life
Jun 12, 2002 04:33 PM
