looking at a 280Z
Old Apr 17, 2003 | 09:49 PM
Speed's Avatar
Wiring Harnesses?
I guess it depends on how close you are to the Gulf in TX?
Up here in Washington, the cars rust out the closer they are to a water source. A car with rust on the coast, generally also has corrosion in the wiring harness. If your in a dry area of Texas, your wiring harness may be just fine. If your talking about a 75 - 78 Z, I believe the alternators were only around 65 amps. I am currently running a 100 amps alternator with no problems. If you decide to run a big amps/watts sound system, you may need to do additional wiring, and possibly an alternator greater than 100 amps. There are kits for Chev's alternators into the Z's. Best thing is to look at the harness. If its got corrosion, you may want to hit some of the wrecking yards in the dryer area of Texas and replace it.
Hope this helps!
Speed
