ZDriver.com
-   240Z, 260Z, 280Z (S30) Forums (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/)
-   -   L28 bored to 3litre? (https://www.zdriver.com/forums/240z-260z-280z-s30-forums-9/l28-bored-3litre-833/)
AlansZ Oct 19, 2001 08:20 PM
I looked at a 240z today, and the guy said the L24 had been bored out to three litres. Correct me if i'm wrong, but I wouldn't think that the block could have that much taken out form it, and if it could wouldn't the block be really weak?
AlansZ Oct 19, 2001 08:21 PM
Re: L28 bored to 3litre?
do Americans use litres when talking about car engines? or just when japanese cars? Do you still use Cubic Inches, or just when talking about a type of engine?
Skaitan Oct 22, 2001 05:11 PM
Well if it is an L28 and not a 2.4, then yes there is a conversion for a 3 litre engine... with a few little trinkets and so forth, so yes, if it's an L28 block, it could very well be
"What do you mean I need to hang on to the wheel at 100 mph?"
JohnCoffey Oct 26, 2001 10:32 AM
Its fairly common to overbore and stroke (using a LD28 diesel crankshaft) one of the L28 blocks to get a 3.0 to 3.2L engine.
John Coffey
johnc@betamotorsports.com
Skaitan Nov 2, 2001 11:53 PM
I know that the F54 block is thicker and usually the choice for most people, but I'm not the most knowledgeable person on the subject...
tyco1983 Nov 4, 2001 10:20 AM
No, if your bore it out +.120, you will not have a lot of metal left. A 2.8 over .120 takes it to 3 liters. By this time, the block is sonic testic, magnafluxed, etc. to make sure the thin cylinder walls will be able to handle the hp without flexing during operation which can be a engine destroying flaw.
