L Engine program needed
I was wondering if anyone had a copy of the program called L Engine as mentioned in the diesel crank stroker buildup page. i followed all the links and tried to find this program, however it's not at it's listed website address... or rather should i say, the entire site is missing/not responding from http://infovfj.ozemail.com.au.
if you have this program or know of where i can get it, please e-mail it to me at robb@lanparty.com or post a web address. thanks in advance. |
Re: L Engine program needed
i have it. i will email it to you
-Matt |
Matt,
What is this L engine Program ?? Can you send it as an attachement for us to check it out. Mike |
Quote from the Diesel crank buildup page...
"...Walter Fath of the Z car club of Sydney put together a great Windows based program which calculates various engine combinations called L Engine. You can try a 280 crank in a 240 motor with 89mm pistons and a E31 head. It will tell you the compression ratio, displacement and other valuable information. It allows you to try different combinations quickly without the cumbersome math..." |
Okay, its basically the same information that is given
in the Nissan Motorsports Catalog for modifying the L motor. Mike |
Hey CrazyLotusTT
Can you email it to me.... That's the link I couldn't find :( PS.. If you're wanting to use the 240Z 9mm.... What I am using... Is from the Maxima non diesel L24 1/81 til 6/81. They are the same as the 240's 9mm, but newer :) Donna |
Hey Donna,
Do you know if the casting is any different then the 240's 9mm rods, or are they just a newer manufactured date ? In other words a new set of 240 rods would be the same casting as the Maxima... I think I am confusing myself [img]/w3timages/icons/smile.gif[/img] Mike |
i don't think the attachment attached. it's pretty big, 622kb. if anyone is interested, email me and i'll get it to you.
david.a.palermo@aexp.com David 1TuffZ zccr.net https://www.zdriver.com/rides/spec/p...1016465706.jpg |
Careful.... L24 maxima rods have a smaller journal one one end (can't temember which).
Ben Adelaide Sth Australia IZCC#1902 240Z L31ETT L28ET MR30 Skyline FJ20ET DR30 Skyline RS-X |
And here's the key info....
Do a search for Sydney Z Club on Google & the #1 link is it. http://www.zcarclub.com.au/ (see the technical articles section) Ben Adelaide Sth Australia IZCC#1902 240Z L31ETT L28ET MR30 Skyline FJ20ET DR30 Skyline RS-X |
