HVLP paint guns
Well, maybe one more
From: Far away, locked up from anything interesting, almost in the dead center of the US
Re: HVLP paint guns
I asked around a little, and the general opinion was no. Sounds like it would work, but not effeciently enough to do a good job.
Good luck,
Ghost
Good luck,
Ghost
Guest
Posts: n/a
Re: HVLP paint guns
Hi Datto and HI Ghost------------HVLP guns unfortunately are here to stay in the paint and body shops----------You asked good question as to whether or not your compressor could handle the task-------------this ofcourse has a two part answer-------first would be that yes your compressor could handle the use of the HVLP gun, but only for limited bursts----------basically probably no longer than a 2 or 3 minute spray cycle-------The second answer would be no----------due to the high volume of air the gun uses the spray pattern could vary during the spraying-----which would leave uneven to blotchy coverage to the painted surface...................
I use both convential siphon cup guns and hvlp guns in my work--------but out of the two different types of guns I use i prefer the siphon gun(I have boths a binks 18 and a devilibiss 502)--------------both of my siphon guns are over 25yrs old but they just keep working better with age............
I do have about 6 different HVLP guns and quite honestly I prefer not to use them-------------These guns were originally created to help prevent the formation of overspray-----------to be honest they create more overspray to the object that you paint and less to the atmosphere------where as the siphon gun creates more to the atmosphere but less to the object being painted-------------so yes the pluses and minuses are still at work-------------The HVLP guns use enormous amounts of air for their operation------they do use a little bit less paint(but not that much)--------they are ackward to paint with------and they take lots of time to dial in both the air pressure and spray patterns for perfect application--------
I hope this little info helped
LaterZ, 81 TURBO
LaterZ, 81 TURBO
Guest
Posts: n/a
Re: HVLP paint guns
hey guys
i ended up buying a HVLP gun. my friend who works at the body shop said it'll be ok just as long as your not painting 10 cars a week. im just painting my flares and bumpers and rims for starters. i bought the gun for 40 bucks from a friend..we'll see how i like the gun..ill keep yah posted when i try it out....thanks for all the help.
datto
datto
