1977 280z fuel gauge issue
Old 11-17-2017, 02:52 PM
Dreadnought4629's Avatar
So my fuel gauge doesn't work. My fuel sender works and i have continuity to it and 12v to everything. I took the gauge apart and cleaned the contacts inside reassembled it and it kinda worked but the needle was never consistent and it would just rise and fall repeatedly and then it just stopped working again any advise??
Dreadnought4629 is offline
Old 11-19-2017, 05:38 PM
I have a present for you...
theramz's Avatar
The sending unit sends OHM readings. You need to pull the sender out of the tank and clean the tabs on the bar. Then check OHM reading across the +/ terminals. It should vary when raising and lowering the float
theramz is offline
Old 11-19-2017, 11:09 PM
the sending unit is working properly and clean
Old 11-20-2017, 09:25 AM
theramz's Avatar
A positive continuity test will show ok if the is a short to ground. You need to test OHM readings to be sure. Check it at the sensor terminals with the wires disconnect to prevent a false reading. If that shows ok then test the terminal ends at the gauge disconnected sensor ends hooked up.
theramz is offline
Old 11-20-2017, 11:04 AM
Yes I ohmed the sending unit its in the gauge I'm asking if there's a specific way to repair the gauge I got it to somewhat work by cleaning the "points" I guess you could call them, inside the gauge but the gauge would rise and fall rise and fall. Would it screw up the sending system if I fixed those points to not open?
Old 11-20-2017, 12:17 PM
theramz's Avatar
Not sure but I see gauges all the time on ebay
theramz is offline
Old 11-20-2017, 01:22 PM
but no guarantee that it works
Old 11-20-2017, 02:11 PM
theramz's Avatar
If it doesn't work you can return it for a refund, ebay rules
theramz is offline
Old 11-20-2017, 02:41 PM
yea true but no money at the moment job hunting sucks
ThatDude114
06-15-2014 08:43 AM
76 2+2
01-08-2012 07:55 PM
sh4d0w
06-15-2011 09:49 AM
Ramen Sama
04-28-2003 06:26 PM
Quick Reply: 1977 280z fuel gauge issue
