1977 280z fuel gauge issue
Old Nov 17, 2017 | 02:52 PM
Dreadnought4629's Avatar
So my fuel gauge doesn't work. My fuel sender works and i have continuity to it and 12v to everything. I took the gauge apart and cleaned the contacts inside reassembled it and it kinda worked but the needle was never consistent and it would just rise and fall repeatedly and then it just stopped working again any advise??
Old Nov 19, 2017 | 05:38 PM
theramz's Avatar
I have a present for you...
The sending unit sends OHM readings. You need to pull the sender out of the tank and clean the tabs on the bar. Then check OHM reading across the +/ terminals. It should vary when raising and lowering the float
Old Nov 19, 2017 | 11:09 PM
the sending unit is working properly and clean
Old Nov 20, 2017 | 09:25 AM
theramz's Avatar
A positive continuity test will show ok if the is a short to ground. You need to test OHM readings to be sure. Check it at the sensor terminals with the wires disconnect to prevent a false reading. If that shows ok then test the terminal ends at the gauge disconnected sensor ends hooked up.
Old Nov 20, 2017 | 11:04 AM
Yes I ohmed the sending unit its in the gauge I'm asking if there's a specific way to repair the gauge I got it to somewhat work by cleaning the "points" I guess you could call them, inside the gauge but the gauge would rise and fall rise and fall. Would it screw up the sending system if I fixed those points to not open?
Old Nov 20, 2017 | 12:17 PM
theramz's Avatar
Not sure but I see gauges all the time on ebay
Old Nov 20, 2017 | 01:22 PM
but no guarantee that it works
Old Nov 20, 2017 | 02:11 PM
theramz's Avatar
If it doesn't work you can return it for a refund, ebay rules
Old Nov 20, 2017 | 02:41 PM
yea true but no money at the moment job hunting sucks
ThatDude114
Jun 15, 2014 08:43 AM
76 2+2
Jan 8, 2012 07:55 PM
sh4d0w
Jun 15, 2011 09:49 AM
Ramen Sama
Apr 28, 2003 06:26 PM
