fuel injectors ?
Old Jul 11, 2012 | 05:18 PM
wallace millner's Avatar
fuel injectors ?
I changed my injectors,is there an order that they have to be in or just replug.
Old Jul 11, 2012 | 05:57 PM
ThaPimpShrimp's Avatar
I assume you mean the clips for the harness? Yes there is definitely an order..
Old Jul 11, 2012 | 07:16 PM
where can i find the order
Old Jul 11, 2012 | 08:08 PM
ZZzzz's Avatar
the electric plugs need to be in order, but it doesnt matter which injector goes into which port. if you have the stock efi harness, its pretty intuitive, as the wires have probably been bent the right way for 30 years. if nothing else...
However, to go the right way, Nismopick has posted a link somewhere where you can download the FSM (that is "factory service manual") if you search for it (i.e. use the forum's search function) you will need to peel back the wire insulator to find the color of the wires, and look on the wiring diagram for the efi harness. that will tell you in which order they need to go.
next time, when you remove the clips, label them in order so you dont have to worry about that
Old Jul 11, 2012 | 08:22 PM
Or label them now so you won't forget next time
All of the FSM's can be found on Xenon's websites.
XenonS30
Old Jul 13, 2012 | 08:42 PM
thanks
Old Jul 14, 2012 | 02:56 PM
I know on my 280zx there isn't an order of where the injector plugs go. These systems are batch fired. It shouldn't matter, I have swapped them out every which way. And the car still runs the same. I am sure the 280z is no different. Or am I wrong?
hardenstine
Aug 17, 2010 09:56 PM
TeamRonin
Oct 6, 2009 10:24 PM
280zinkansas
Apr 27, 2004 10:26 AM
NwZXlover
Jul 28, 2003 08:52 PM
lifegrddude
Oct 29, 2001 09:44 PM
