frame check
Guest
Posts: n/a
Re: frame check
look for creases near the firewall on the box section of the chasis and near the front radiator former ... they usual dent around there ... also take a tape measure and measure from on corner of the engine bay to the other (diagonaly) and do it on the other side ... if the measurements are the same you are ok
eg from front left corner of radiator former to right side of firewall then do it from front right to back left etc...
72 240Z restoring
72 240Z RB25DET Conversion
78 260Z 2+2 Daily Driver
72 240Z restoring
Re: frame check
Also, if you are driving down the street and you have to keep your steering wheel turned to one side just to stay in the lane then your frame might be bent!
Or, if your car looks like the attached image above, then your frame "might" be bent.
nka04a
Nov 19, 2005 06:55 PM
BASEBALL248
Aug 19, 2003 09:06 AM
thats a long way !! time to go to a pannel beater with a jig !! or a puller
