Differnce Between 240z's and 260z's
Old Aug 28, 2003 | 10:35 AM
auxilary's Avatar
the Dude
260 was available with an optional 2+2, had a 2.6 liter engine with e88 head and flat top SU carbs, just like a '73 240z. It also had 280z taillights and 240z front turn signals, along with big ugly safety bumpers. dash was slightly different.
everything else is basically the same
Old Aug 31, 2003 | 10:27 AM
Creator's Avatar
Yup body styles are practically identical, all parts of 240z/260z/280z's are swappable (assuming all 2seaters).
The only major difference in the 260z's is that they had storage bins behind the seats (good for hiding random things from would-be burglars), and the front frame rails and firewall were slightly thicker (as part of the crash/safety conventions of the mid 70s).
Overall the 260z (1974+) was about 200lbs heavier then the early year 240z (1970, 71, 72); this is from the thicker sheet metal, and the addition of the r200 (i think it was standard on 260z???) rear end.
All in all, the 260z *should* make a better body for high horsepower engines due to the thicker frame/firewall (more torsional rigidity).
Also, 260z's are fairly rare, since they were only imported for 1 year (1974, 74.5), whereas 240z were imported for 8+ years, and the 280z for 3 years (1975-78)
Old Sep 1, 2003 | 10:30 AM
Creator's Avatar
Err, ya got me there. Althought i've seen some 1973.5 240z's (which were technically the 74 year, not that it matters). But yup, i do stand corrected.
Old Sep 15, 2003 | 09:41 AM
Creator's Avatar
Yup, a 260z with SU Carbs and Carbspacer rock! heh, especially if you reneedle them, and do all the 240z/SU Carb tricks
Old Oct 15, 2003 | 09:02 PM
Spudz's Avatar
Let me answer this one ..
Here is what I know ......
There are two versions of the US based
260. One was built along the 240 lines
with a step up between the 240's bumpers and the late 260's big bumpers.
They had the heavier impact absorbing
cylinders behind the bumpers. It has the 240 suspension under it and did not come in a 2 + 2 model. It is considered the 74'
260.
The late 260 was built until the fuel injected 280 could be released . For what I understand the injection wasn't ready yet and Nissan released the body of the
280 with the 260 motor and the smog flat tp carbs. This considered a 74 .5 260 and it did come in a 2+ 2 model. It also used the 280's suspension. It had the huge energy absorbing bumpers that the earlier 280's had.
I have the late 260 in my garage and also a 73' 240 .
Mike
Old Oct 16, 2003 | 02:43 PM
Hmmm... that quote from me looks more like some one asked about the difference between a 240Z and 260Z 2+2. Anyway... everyone else covered it much better than my above quoted self.
Originally posted by Airpilot16
I asked the same question, and BleachZee said:
Old Feb 2, 2004 | 10:25 PM
GARYZ240's Avatar
All 240Z built after 1970 had the storage bins on the rear deck behind the seats. The late 1969 - 1970 built (Series I) cars had plastic storage bins on the floor behind the seats. These cars also had the fresh air vents in the rear hatch, ashtray in front of the gear shift and several other small differences. These differences slowly transitioned into the newer (Series II) style in 1971, with some having a mixture of the early and later cars until they gelled into the 1972. The storage bins in the rear deck were continued on in the 260Z and 280Z in both 2 seater and 2+2. See http://www.zhome.com/ for more info on the differences in the cars as they evolved.
Old Feb 15, 2004 | 09:45 PM
Riz Z Speed's Avatar
Administrative Brown Guy
Keep it up guys.
I think I'm starting to learn something here....
UtahZ
Apr 24, 2014 12:12 AM
Ratfink
Jul 2, 2008 08:00 PM
FubarI33t
Sep 17, 2005 11:08 PM
adamjoh
Sep 29, 2002 07:27 AM
