Differential
Two questions:
One what type of Oil 80-90w? Two how do I find out what differential i have when i went to get a gasket they listed 2 r100 and r 200 (April-1978 Datsun 280 z) |
thanks for all the help
If you have a 4/5 speed it should be an R200. If it's an Automatic it'll be an R180. But with as old as these cars are it could have been swapped at any time. Check HERE and see if you can figure it out. Shouldn't be hard.
Quick google search renders this:
R200 on the left... R180 on the right: http://zhome.com/rnt/L28conversion/Diff.jpg |
thank you much
r-200 is what i have on my 1982 280zx turbo i used sysntec 75-90 gear oil it was expesive as hell for me 17.99 a liter mine took 1.5 liters i used the rest in to clean out anything in the rear gears " GET A GAS MASK ! " that rear gear oil will make u vomit on smell and look alone. At least it made me feel very sick i think it was worse because i heated up the gear oil took it out on the free way then came home and changed it out.
OMG What a Pain in the aZZ... I can not seem to get the mounting nuts loose. Also can not get the drain plug loose either.I am replacing bushings as i am going.
Which mounting nuts? The 4 connected to the cross member, or the 2 on the mustache mount? Use an impact gun on the 4 base ones, or a breaker bar. You should also soak them in some PB Blaster for a few, before removing them.
Gear oil
also, never, and I mean NEVER washes out of clothes unless someone knows a secret that I never learned...
What is up with the drain plugs They are 3/8 or 1/2?
ummm errr i ment 1/2 or 3/4..... sorry
Drain and fill are 1/2 drive ( use a BIG breaker bar. these are TIGHT)
Z-bar mounts. 17 ML Front mount. 14 ML Front yoke 12 ML Drive axles.. 14 ML That help? Todd/BC240Z |
Thank you
I gave Up going to take it to a shop that can get it on a lift. I wanted to replace seals and clean it out. but forget it... |
R200 on the left... R180 on the right: http://zhome.com/rnt/L28conversion/Diff.jpg rx |
Originally Posted by rxKaffee
My diff has the two lower plugs with the inset hex-heads like the r200 on the right, but its not so rounded looking and kinda looks like the verticle rectangle shape of the leftward r180... any thoughts on which it might be? I've got an 82 or 83 5spd.
rx I think you have RIGHT and LEFT mixed up. :D The R200 is on the left, R180 on the right. If you have an 82-83 w/ 5speed, you have the R200. See this website: http://www.geocities.com/z_design_studio/ |
