datsun 280z 1976
Old Dec 7, 2003 | 11:24 AM
emo236's Avatar
confuzed member
There's a lot that you could do. Like Allmyz said, you could do head work on it. Also, have you considered the turbo motor. You wouldn't be abandoning the L-28, you'd just have a lot more power and a lot more potential. Also, I appreciate your traffic here, but I think you'll find a lot more info in the 280zx forum. most of us here are more knowledgeable about your dad's car and its VG. Good luck with the car!
Old Dec 7, 2003 | 12:28 PM
craZed's Avatar
Re: datsun 280z 1976
[ it was stressing to go over 100mph in it's final 4th gear. The rpm's were at 6000
IF THATS TRUE THEN THE FIRST THING YOU WANT TO DO IS HAVE YOUR CLUTCH CHECKED OUT .3RD GEAR SHOULD PUT YOU AROUND 100.ONCE YOU HAVE YOUR CLUTH RIGHT YOU WILL BE ABLE TO SEE WHAT YOUR MOTOR IS TRUELY CAPABLE OF IN ITS PRESSENT STATE.THOES MOTORS ARE KNOWN TO RUN STRONG PAST A QUARTER OF A MILLION MILES.GOOD LUCK
Old Dec 22, 2003 | 12:47 AM
Riz Z Speed's Avatar
Administrative Brown Guy
(moved to 240z,260z,280z)
Old Dec 22, 2003 | 09:09 AM
It is feasable to beat a 350Z in a quarter mile race with an n/a L28. You'll want to do a bit of weight reduction on your 280Z. Put on 240Z bumpers or just run with no bumpers and maybe add some fiberglass parts front and rear...
Do some porting on the intake ports in the head, port your intake manifold, put in larger injectors and tune your AFM. raise the compression when you rebuild your engine by putting in flat top pistons. run a longer duration cam and put a lower geared rearend in the car. You can get close to 200hp at the wheels with a setup like that. The weight will be significantly lower than a 350Z so you'll have about the same acceleration. Your goal will be a 13.9 second 1/4 mile or less.
The hardest part will be getting just the right fuel mixture. With the proper work your engine will need more fuel but too much won't help you. If you can make or buy a programable computer that will work well.
Old Dec 22, 2003 | 09:32 AM
auxilary's Avatar
the Dude
my opinion:
if you want to put new sports cars such as the 350z to shame, you'll need to have matching power/handling/braking. If we're talking power alone, you'll need to port/polish the head, rebuild your block anyway, and put a stroker kit, such as a Rebello one, in. Expect to spend about 3-4k on this setup, and on pump gas you'll be limited to about 250hp max.
For that cost, I'd just recommend putting in a smallblock chevy, which will come out even cheaper and has tons more potential, as well as daily drivability.
