Cold Start Jerking
Old 10-08-2002, 09:42 PM
Skully's Avatar
Re: Cold Start Jerking
ill check for that too but we had a discussion about this long time ago...like here in canada at -5 lets say i can barely get my car started it turns on and just shuts off right away...i hit the gas it just stalls it it doesnt revv up ....so i dunno before they said this is normal to all Z cars....i dunno
Skully is offline
Old 10-09-2002, 09:07 AM
Mine does that a bit too. I replaced my distributor after finding out tha my vaccume advance was stuck. It helped a lot!
The problem is still there, but not nearly as bad. I can at least drive a little when it is cold. I used to have to just set for a minute before I started out, and even then I would have to be really easy on the throttle. I think it might have something to do with my throttle body. I put on the Motorsport big throttle and ever since I've had a problem with cold starts. It progressivly got worse though untill I fixed the distributor.
The cold-start valve may also be a cause of this. My intake hose appears to be complete. Even when warm, the large throttle has a fraction of a second of hesitation where I remember my stock throttle was so responsive. That's what I loved about my Z when I first got it. I always talk about going back to the stock throttle because I hate everything about this large throttle body! I just never have the time to fix it!
Bleach is offline
Old 10-16-2002, 05:30 PM
Skully's Avatar
yeah thx guys
Skully is offline
Old 10-17-2002, 01:29 PM
If you have a solid rubber piece running from your throttle body to your air flow meter, how do you suggest someone hooks up the cold-start vaccume hoses to the TVV and the valve cover vent hose?
Bleach is offline
Old 10-17-2002, 01:33 PM
Skully's Avatar
oh...i see isee ill have ta check then as soon as the SNOW MELTS OF MY CAR [censored] [censored] *** BITCH !!!!! GOD!!!! lol...sorry
Skully is offline
bongpogi
08-19-2015 11:15 AM
EatmyDust
10-02-2006 08:12 PM
Craig_Paterson
08-14-2006 09:32 PM
FranksZ31's
05-17-2006 02:36 AM
innerware
03-13-2002 08:50 PM
Quick Reply: Cold Start Jerking
