Chevy V8 vs. 280zxturbo
Old Apr 10, 2003 | 06:22 PM
veyenyl's Avatar
I've owned a V8 Z and now own a turbo Z. For the V8 swap you will need a chevy tranny and new motor mount which is well documented in the links mentioned. Some people prefer the turbo swap cause it's more of a direct swap (same mounts, same tranny).
As far as costs go, it all depends on your hp goals for the car. If you are looking to build a 400-500hp monster then the V8 will cheaper, easier, and probably more reliable. If you are looking at the 300 hp range it can be done either way. I don't think a turbo conversion is necessarily cheaper. It all depends on how much you get your donor engine for. All the other parts like intercooler, piping, and fuel management to get to 300hp add up. With a V8 you could buy a 350hp crate engine drop it in and be done with it.
I guess it comes down to what you want out of the car and what you prefer working on.
Old Apr 22, 2003 | 11:41 AM
veyenyl's Avatar
The V8 will not negatively affect handling. With the engine all the way back against the firewall you can get close to 50/50 weight distribution. On a turbo car the intercooler and piping in the front of the car will bias the weight more towards the front but they will both handle great with a good suspension setup.
BlueKitsune
Other Cars
57
Nov 14, 2009 11:34 AM
nismo619
Jun 10, 2006 03:56 PM
280zExTURBO
Nov 17, 2005 08:52 AM
turb0m0
Apr 7, 2003 12:23 AM
mck2
Jul 1, 2002 07:21 AM
