blown turbo head gasket at 10psi
Old Aug 8, 2002 | 08:58 PM
zguy36's Avatar
Dead
Re: blown turbo head gasket at 10psi
SCE Gasket... Get your block o-ringed at a machine shop and make dang sure that you block and head are flat before you put it together. Use a gasket sealer on your copper gasket that contains hylomar. Most of the other stuff will leak.
-jeremy-
Old Aug 9, 2002 | 05:12 AM
1tuffz's Avatar
my head gasket went away last year and i did the following: nismo/hks metal head gasket [choice of either 1 or 2mm depending on your compression ratio requirements] and head studs-not bolts. i used arp. called them direct to understand the difference b/w studs [i was using the nissan turbo bolts] vs. bolts. here's the skinny-studs provide greater clamping pressure also allow more consistent torquing. due to the nature of the stud material the clamping pressure increases as the head comes up to temp [alum. expands as it heats] but the studs don't expand/stretch. it took an engineer 30min. to explain all of this to me. follow the directions on the arp box for tq specs. i listened to someone who i thought was a reputable engine builder who sold me the studs [he rcmd a much higher tq than arp] and i sheared a stud off in the block-able to get it out but...
anyway, running more boost now and have seen no probs so far [knockin' on wood].
hope this helps!
David
1TuffZ
zccr.net
Old Aug 12, 2002 | 11:56 AM
1tuffz's Avatar
i believe the arp stud kit was retail from arp $141.16, less thru a local source, good for more hp, don't know how much exactly. website:
www.arp-bolts.com
also: [info on studs]
http://www.arp-bolts.com/pages/produ...headstuds.html
part #202-4206
David
1TuffZ
zccr.net
borini63
Sep 13, 2012 11:00 AM
macmandan1
Nov 24, 2011 10:11 PM
skittle
Jan 26, 2007 10:16 PM
280z4life
Jul 16, 2006 09:42 PM
Fast240Z
Other Cars
Oct 7, 2005 10:13 AM
