Best Mods?
Old May 11, 2001 | 02:14 PM
Re: Best Mods = gears!
Its all in the gears. Tune up your engine, and then stick in the right transmission and rear end. That's what I've found out works good for very little money and very straight forward work. All you do is undo bolts, and put new ones in.
Get a 1975-78 280Z 5-speed. (fairly low gears for 1st-3rd) and put in a 3.9:1 or 4.11 geared differential. It feels great and drives good. It gets you to those high rpms a little faster too and compliments a good cam VERY well.
Also, you may put in a T-5 Borg Warner 5-speed
(1982-83 280zx turbo)
but that will just require a shortened driveshaft. It has much lower gears in it. The 280Z five-speed is an easier install.
Old May 15, 2001 | 07:09 AM
Actualy, the 1983 280ZX turbo with a borg warner T-5 has the same bolt pattern and will bolt up to any L28. I have one in my garage! But it is the longer style of tranny like all 280zx's. If you're putting a 280zx tranny (including the T-5) into a 70-78 Z, then you will have to have the driveline shortened. That's why I suggest using a 280Z 5-speed for ease of installation.
The R200 4.11 was on the 1985-86 200SX Turbo only. They do not burn up the fuel economy. For all the torque it adds, you're only about 250 rpm higher at 70mph. As long as you have a 5-speed, don't worry about using a 4.11 rear. I had one on a daily driven 280zx and it was great! When you're driving on the highway, the L-6 engine is pretty efficent at 3000 rpm.
Old May 16, 2001 | 08:39 AM
Re: Driveshaft
Take it to a shop that works on driveshafts. Usually, you can find a shop specializing in driveshafts and transmissions. A driveshaft needs to be welded very strong and then balanced, so just about everyone has that done for them. Its just one of those things that you don't do yourself, like shaving an engine head.
4rdhater
Nov 22, 2002 04:53 PM
blink
Oct 31, 2002 02:12 PM
SoonToHave1
Jul 22, 2002 10:13 AM
rick84
Jun 13, 2002 10:37 AM
Z_For_Life
Jun 12, 2002 04:33 PM
