advice needed
Old Aug 27, 2001 | 03:09 AM
silvrhand's Avatar
Snazzy Title
Re: advice needed
Welp,
The headers expand and contract with heat, so as the car heats up things expand, then when it cools down they contract. Sudden heat changes from very hot to very cold can cause things to crack. Such as headers, blocks, and bolts. But you also have to realize that your car is now 18 years old. Things like this may happen if the car was mistreated.
As for the bolt this is a tough one, I don't think the block is aluminum so it at least won't strip out the threads.. You can try to drill a small hole into the bolt, then tap it with some left handed threads and screw another bolt into it to see if it comes out. That'll require a few trips to a hardware store to find left handed thread tap and dye set though..
Good luck.
- John
The best thing
- john
sams240z
Apr 3, 2013 08:23 PM
BackHouseZ
Jul 12, 2008 04:47 PM
tyyr
Aug 20, 2004 01:54 AM
rebelz12
Apr 12, 2003 07:12 PM
Beaker
Sep 16, 2002 04:49 PM
