280zx Fuses?!!..Help!
Old May 10, 2002 | 12:09 PM
lifegrddude's Avatar
Externally Wastegated
Re: 280zx Fuses?!!..Help!
I had my dashboard and tail lights go out on me before once. It was the fuse in the fuse box located on the passenger side. I'm pretty sure it's a 15amp fuse in the first column of fuses going down. The blinkers might not work due to a bad connection somewhere. I found mine were loosely connected and that caused them to work intermittently. Good luck and I hope this helps.
82ZXT
Old May 10, 2002 | 08:23 PM
Skully's Avatar
same problem here my lights cut out, dash lights cutt out, blinkers cut out etc....
just because the fuses are loose in the housing when i press harder on them i get my things working so im gonna havta get some plyers and squize the fuse housing
also mine fuse housings are pretty dirty so ima havta clean em too check for that too
wooohooo done done finaly done
280Venile
Apr 24, 2013 04:47 PM
Niku-Sama
Mar 16, 2008 06:17 PM
DynamicJ
Feb 17, 2005 04:27 AM
Skully
Sep 30, 2003 05:13 PM
cassarly1
May 21, 2002 02:07 AM
