2 questions... (suspension and clutch)
Old Jul 18, 2003 | 11:13 AM
zpeedracer25's Avatar
Check with your local auto parts stores. A lot of them will rent out tools and may have a spring compressor to rent as well.
Your loss of fluid is likely to failure of the clutch master, slave, or hydraulic line to the slave. If the master is leaking you'll have fluid leaking inside your car, so check the fire wall behind the clutch pedal. If your slave or line is leaking you'll probably have fluid hitting the ground. Any of these is fairly easy to replace. Just make sure to bleed the system well after replacing them.
Have fun working on your Z!
xracer13
Aug 16, 2012 03:53 PM
Blue83
Sep 26, 2008 11:25 AM
robert
Aug 24, 2004 08:11 PM
pearly whites
Dec 17, 2003 07:47 PM
ex247
Feb 28, 2002 01:23 AM
