Wiring Harness Swap
Old Jan 28, 2008 | 08:30 AM
Mitchka's Avatar
Wiring Harness Swap
I have a late 1974 260Z, and I need a dash wiring harness for it. I found a guy who has a 1975 280Z dash wiring harness.
If my memory serves me right, everything under the dash is the same? I searched the forums, and I didn't find anything on the differences yet.
Thanks for any help you can provide,
~Mitchka
Old Apr 24, 2025 | 08:38 AM
theramz's Avatar
I have a present for you...
The late '74 is exactly the same. A few months later the 280z was introduced. Only diff was the bore size. Just make sure you mark both sides of each connection or you will have a possible nightmare. Change up the fuse box too with the correct size fuses. As the fuse box terminals got corroded and blew fuses the owners would put higher amp fuses and overload the system. See past related threads
Solhaven
Apr 19, 2013 09:53 PM
hoov100
Mar 5, 2006 08:31 PM
Mirah
Feb 15, 2005 10:44 AM
KraZ4spd
Apr 4, 2001 07:25 PM
