Wiring a GM alternator
Old Jan 24, 2006 | 09:23 PM
alanq64's Avatar
Anyone have pictures or a step by step for wiring up a GM alternator?
Old Jan 25, 2006 | 05:53 AM
240zprace's Avatar
one wire or 3 wire gm alternator..... check out this site zcarcreations.com
Old Jan 25, 2006 | 06:51 AM
alanq64's Avatar
Thanks, seen that one. I'm needing a wiring diagram on how to do it. I have to go back to ft. sill on friday (wednesday now) and I wanted to have this done before the trip.
Old Jan 25, 2006 | 07:13 AM
You just hook up the battery wire & that's it for wiring... What alternator you using? A new one from a parts store, or one from the junk yard?
You will prolly need to modify the alternator to fit the Z bracket. I just cut it to fit on mine. Oh, and you'll need to swap pullies.
Old Jan 26, 2006 | 09:56 AM
alanq64's Avatar
I was under the impression that it was better to do a 3 wire setup than a single wire.
Old Jan 26, 2006 | 12:59 PM
Better in what sense? The alternator creates 14.7v of electricity to run back to the batt... You only need 1 wire to do that. The more complex wiring harnesses are for voltage / amp checks, etc...
Old Jan 27, 2006 | 10:27 PM
alanq64's Avatar
I'm wanting to use the voltmeter in my Z. Could a bad regulator cause my running/dashboard light fuse to blow?
soysauce300zx
Nov 2, 2014 08:54 AM
Nick Napala
FS: 300ZX (90-96)
Feb 7, 2014 01:55 AM
jtessmer
Jun 13, 2013 05:08 PM
Daniel Coffman
Apr 14, 2013 06:36 PM
SHADY280
May 6, 2006 02:28 PM
