Voltage Regulation Issue (volts jump uncontrollably)
Old Sep 21, 2013 | 06:26 PM
ammorri2's Avatar
My voltage gauge bounces between 12 and 16 while idling at startup. As soon as I give it gas, the voltage spikes to the max reading the gauge will read. This started happening after I cleaned the fusible links with a brass wire brush without disconnecting the negative battery cable. A spark shot from the link terminal through the wire brush into the bracket that holds the fusible links. I thought it was the voltage regulator that was fried in the alternator, but after installing a new alternator, the problem persists.
Old Sep 21, 2013 | 06:31 PM
ammorri2's Avatar
Sorry, the cars a 1978 280z.
Old Sep 21, 2013 | 08:14 PM
Zdon's Avatar
Voltage spike on 1978 Z
Mosts likely it's your alternator preparing to go out.
Old Sep 21, 2013 | 09:06 PM
ammorri2's Avatar
Thanks for the reply but it's not the alternator or voltage regulator. As I said above, even after changing the alternator, the problem still existed.
Old Sep 22, 2013 | 06:55 PM
Are you sure you got an internally regulated alternator? The 70-77 S30's use an external voltage regulator.
Simple solution: drive your car to your local parts store and have them do a load test on your alternator / battery.
FYI: Parts store reman alternators for the Z are notoriously duff.
Old Sep 22, 2013 | 08:11 PM
ammorri2's Avatar
Yea it's definitely an internally regulated alternator. I took the original alternator to autozone and it passed all three tests. What else could cause the voltage to spike uncontrollably in spite of a good voltage regulator? Or better yet, what would cause a good voltage regulator to misbehave?
thekid
Oct 25, 2013 10:01 PM
Mike Phillips
Jun 6, 2008 10:15 PM
mck2
Jun 4, 2002 06:26 AM
mck2
Jun 3, 2002 02:35 PM
mck2
Jun 3, 2002 02:34 PM
