transmission removal
I am trying to replace the clutch in my 1979 280 zx and have a question about removing my transmission. In the chiltons manual I have it says to remove the exhaust pipe from the manifold. I tried to do this but since the nuts are rusted on to the bolts I ended up shearing off one of the bolts. Now I don't want to shear off the last remaining bolt because that one is rusted too. I was wondering If it is really necessary to remove the exhaust pipe and if you guys think it will be ok to attach the pipe to the manifold using 2 out of 3 bolts because thats all there are left.
Thanks for your help guys! |
Re: transmission removal
That's typical for those fasteners. Yes, you do need the exhaust off & yes you do need to have all 3 fasteners present & tight.
Take it slowly, use lost of lubricant & some voodoo magic wouldn't hurt too.... Over here there are a number of mobile thread-repair businesses that specialize in removal/repair of broken fasteners/threads. It usually cost ~$50 per thread, if you wanted to go that way. If you only use 2 of the studs then the exhaust will leak bigtime. Ben Adelaide Sth Australia IZCC#1902 240Z L31ETT L28ET MR30 Skyline FJ20ET DR30 Skyline RS-X |
awww fawk so exhaust has to come off too!!!??? damn it...
I'm screwed! My exhaust pipe is custom and has a custom collector. The whole setup is one piece welded right to the headers. I need to change my transmission very soon....
http://www.zipcon.net/bleach/pages/zcar/zlogo.jpg |
Thanks for your help Ben. I guess now I have an excuse to get headers :)
Are you sure you can't unbolt the transmission and then with it on a transmission jack, roll it to one side a bit and turn the tail end away from the exhaust a little???
I guess I'll crawl under there and see for myself. http://www.zipcon.net/bleach/pages/zcar/zlogo.jpg |
