tranny problems HELP!!!
Old Jan 24, 2004 | 07:15 PM
theramz's Avatar
I have a present for you...
If the oil is black, it's because the seals have deteriorated and contaminated the fluid. You will have to replace the clutch master cylinder. While you're at it you might as well replace the slave cyclinder too. You can verify this by having someone press down on the clutch pedal while you observe the arm on the trans, if it doesn't move at least 3/4 of an inch then your master and slave are probably junk.
Old Jan 27, 2004 | 04:48 PM
Z*Tech's Avatar
shifting problem
I am assuming that you have a 4 speed manual trans? Look into replacing the master and slave cylinders for the clutch, after sitting and the hydraulic fluid absorbing moisture its not uncommon for these to go bad.
Old Jan 28, 2004 | 11:54 AM
zr8d's Avatar
if none of those work you're going to have to take the tranny out and make sure the clutch assembly is working. it could be something as simple as your clutch fork slipping off the pivot point inside the transmission or your throw out bearing could be shot.
Old Jan 28, 2004 | 06:23 PM
Z*Tech's Avatar
Years ago the tranny in my 76 2+2 didn't want to shift, I used a mixture of 6 parts 90wt gear lube and 1 part type F automatic tranny fluid and that resolved the shifting problem. Still running the same tranny and after many, many miles its still smooth as silk. When ever I service the trans I use the same mixture.
lemitless300zx
May 5, 2011 02:32 PM
nismaniac
Jul 23, 2006 10:30 AM
LittleblueZ
May 16, 2006 12:52 AM
gabrielzzz
Oct 26, 2005 09:05 PM
GOMEZGOGO
Dec 4, 2003 12:31 PM
