shaving head 0.080 info maybe a new trend, no shims needed
Old Jan 22, 2004 | 09:00 PM
theramz's Avatar
I have a present for you...
The problem with this is that there are still 42 links between the timming marks on the sprockets. A decrease of .080 in the distance between the crankshaft and the cam means the cam will be retarded approximately 2 degrees. This can be over come by noting the timing marks and advancing the cam by using one of the three locating holes in the cam. Each hole is 4 degrees. Normally this procedure is used to compensate for chain stretch.
Old Jan 23, 2004 | 07:42 AM
Doesn't sound like there is a problem with it. You set the sprocket #2 position on the bright link and then slide it onto the cam #2 hole. That advances the cam enough to more than make up for the head shaving. Then the idea of the Z22 chain tensioner takes up the slack.
Advancing the chain a little helps if anything with your power. Usually this is done to add some more torque while sacrificing a little high rpm power, but others have said the upper end power is not lost.... so advancing it a small amount won't hurt anything.
Old Feb 4, 2004 | 02:41 PM
Spudz's Avatar
This is a new one to me . What is the estimated increase in compression with an 80 thou shave ?
Mike
cobralini
Feb 17, 2013 08:11 PM
EZDUZIT
Apr 14, 2009 06:29 AM
knb13
Apr 19, 2004 01:29 PM
kuch73
Oct 31, 2002 04:10 PM
ZeeZee
Mar 1, 2002 07:56 AM
