ZDriver.com
-   240Z, 260Z, 280Z Performance / Technical (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/)
-   -   No power when cold (https://www.zdriver.com/forums/240z-260z-280z-performance-technical-124/no-power-when-cold-25421/)
tehweej Apr 14, 2008 09:04 AM
No power when cold
When i start up my z in the morning and drive to work/school, when i accelerate it has power up to about 2700-3000, then it chokes and stumbles and has no power. however, if i let off the gas pedal some, it gets power back (to a point). but when its warmed up its fine. ideas?
NismoPick Apr 14, 2008 10:07 AM
Air regulator & cold start valve... search for those terms (and "cold start") & you'll have your answer lickidy split. :D
tehweej Apr 21, 2008 09:38 AM
ok so i took the air reg off and the bi-metal strip assy. came out rather easily... and i was just curious on the proper operation of the air reg. (does it normally bleed vacuum through it, when is it supposed to be open/closed, how long does it take to do both). my searches came up fruitless :(
NismoPick Apr 21, 2008 10:05 AM
I searched for "REGULATOR" and found these:
https://www.zdriver.com/forums/showt...ight=regulator
and tons of other threads.
tehweej Apr 21, 2008 11:59 AM
it was cold enough today so i could actually see my exhaust whilst driving, and when it bogged down there was a rather large amount of blue/whitish smoke. i know my z burns a little oil, but could the problem be worse when its cold?
NismoPick Apr 21, 2008 12:04 PM
Did ya click on that first link I posted? :D
tehweej Apr 21, 2008 01:29 PM
i guess i was wondering if it might be more than just the air reg (which i am now sure mine needs the niku-sama rebuild treatment). when i pulled mine and blocked all the holes, it ran better and idled lower. btw my idle screw is all in and im idling at about 1k-1100. i did not have a chance to actually take it out for a drive tho.
