N-34 Carb Intake Set Up
N-36 Carb Intake Set Up
:ermm: I have a couple of specific questions regarding N-36 260Z manifolds and connecting the carbs in general. I recently got my hands on a nice set of N-36 Intakes and had them bead blasted. They look pretty nice. I also had a nice balance tube prepped at the same time. I went to connect my early 4 screw roundtops to them and noticed that the studs seem to be shorter. I couldn't get both the lock washer and washer on and barely could thread the nut on with just the washer. Is this normal? Were the insulators narrower on the 260Z's with flat-tops? Secondly, should there be a gasket on both the manifold and the carb sides of the insulator. In other words do I need four gaskets. Probably silly questions. But I'd like to get these set up right before they go on the car. I switched to the N-36 having read they give slight performance boost and looked like something even I could do. http://www.geocities.com/zgarage2001/engine.html
Gary
Gary
Superduner
Jun 10, 2009 10:17 PM
280ZX_AV8R
Jun 17, 2005 06:47 PM
thomas schuchat
Apr 17, 2003 11:26 AM
