Mysterious Wires
Old Mar 1, 2004 | 07:09 PM
theramz's Avatar
I have a present for you...
The two black wires go to that annoying little warning buzzer. The buzzer has self shearing screws that shear off when it is installed. If the buzzer is missing you can plug the two wires together since they are in a dead loop. Not sure what you mean by "inter lock."
Old Mar 2, 2004 | 10:26 AM
theramz's Avatar
Originally Posted by Loggerboy666
It says in the factory manual that when the key is turned to the start position a signal goes through a black and yellow wire to the interlock unit and then to a adapter that loops the signal to the starter through various plugs and different colors of wires. this may be confusing I can refrase it if need be. I tend to be confusing at times.
Thanks,
Randy
The only thing I can think of is it must be to the neutral switch on the side of the trans.
stormhelix
18
Mar 6, 2025 01:00 PM
eishiba
20
Jul 3, 2014 09:21 AM
daPud
Nov 11, 2010 06:10 PM
mrprofile
Oct 14, 2010 07:46 PM
ZWINTERZ
Nov 6, 2003 03:21 AM
