Limits of 77-78 ECU
Old Dec 23, 2003 | 07:26 AM
Carbs can be pretty good too. Properly tuned SU's or tripple sidedrafts.
The ECU is pretty simple and doesn't take much modding. Are you into electronics?
I've heard two different stories on the ECU. One was that it is dual bank firing half the injectors at once and going back and forth. this is like most fuel injection systems. Another source told me it is a single bank firing all six injectors at the same time.
Basically if you want more fuel in the engine, just leave the ECU alone and modify the sensors and swap to larger injectors. For an N/A application you don't need massive injectors but larger ones still help a lot for high rpms. Tweak the AFM or head temp sensor for richness adjustment. You can also buy a progressive rate fuel pressure regulator for N/ A fuel injected Z's.
With your mods you probaby have figured out the stock ECU and fuel system runs lean above 5000 rpm. Open up that intake manifold a bit too. That thing is made for good torque.
Or build yourself a MegaSquirt ECU. Fully programable and it is a two bank design. It has a MAP sensor, no AFM so your intake is more wide open!
madness
Dec 23, 2005 08:14 PM
duckyz
Oct 24, 2002 08:54 PM
