Flywheel bolts
I am currently doing the auto to manual conversion on an L28 for my Z.I would like to know if the original bolts that secured the auto "flywheel" to the crankshaft are the same as those required for the normal flywheel attachment.
They are the same size, however I think the auto bolts are shorter than the ones used in the manual flywheel. Measure thread length and depth of manual flywheel make sure you have enough sticking out to hold that flywheel on at 6500 rpm's. If not just go buy 6 Grade8 metric machine bolts.
Guest
Posts: n/a
Can anyone help me with the torque settings for the flywheel bolts on my L20a fairlady??
also require torque settings for pressure plate too thanx , any help would be appreciated.
