Changing camshaft questions
Old Feb 2, 2005 | 03:44 PM
thunderz's Avatar
Question Changing camshaft questions
I wanted to ask if it is neccesary to have the metal pieces that the cam contacts resurfaced when installing a new cam.
Old Feb 2, 2005 | 06:07 PM
240zprace's Avatar
that would be wise to do... you don't want your new cam to wear down fast,, please have a machineshop resurface the rocker arms :dancing:
Old Feb 2, 2005 | 07:43 PM
Fast240Z's Avatar
yeah, it's a good idea, because the lifters are worn in a certain way, and if you put a new cam into it, the lifters will wear the cam in a negative way.
Old Feb 3, 2005 | 09:43 AM
theramz's Avatar
I have a present for you...
The tops should be milled also because you are correcting the flatness on both sides. You will then need to shim the towers according to how much was removed.
A friend of mine works in a speed shop and he told me you shouldn't hang the engine on an engine stand because the weight of the long L6 will actually bow the block while you are assembling it. It should be setting on the motor mount area and the rear of the block.
campfirestring
Jul 12, 2012 08:04 AM
ekset22
May 21, 2012 10:45 AM
usmc0331
May 23, 2008 06:37 AM
n00blar
Aug 1, 2006 09:17 AM
OlderThanMe
Oct 19, 2004 10:10 PM
