4-speed to a 5-speed
I want to replace my 4-speed in my '78' 280Z with a 5-speed. I'm replacing the clutch anyway. What changes do I need to deal with by going to a 5-speed? I tried "searching" for this info, but was not successful. Many thanks!
All you need is a 5 speed from a '79-'83 280zx. You also need the clutch fork and T.O bearing. Same clutch you already have in.
I sourced one out of Arizona. My clutch is 8 7/8" disc, so I'm thinking of getting the larger one (9 7/16) with a larger flywheel. Are you saying the clutch fork in the car won't work with a 5-speed? Also, the TO Bearing comes with the clutch kit, so I'm assuming it would be correct. Speedo issues? Nice to know I don't need to replace the diff. Many thanks for your help.
Originally Posted by Jon Dingler
(Post 345985)
| All times are GMT -7. The time now is 03:53 AM. |
