Saturn |
11-01-2003 11:53 AM |
You may want to swap your shifter lever from the 4 speed to the 5, I just did the same swap last weekend and the 5 speed shifter has a spring loaded weird bushing in it, the 4 speed dosen't and feels a lot tighter. You will have to switch over your speedometer drive gear between the old and new transmissions unless they are the same color. The gear holders are different and you have to drive out the little pin that holds the gears in the holder and swap them, no big deal. Other than that it is a plug and play!
