280z Headlight goes out when i plug the other one in
Old Mar 9, 2006 | 10:02 AM
brad101010's Avatar
I wanted to find out what somone thought about my problem. When i plug in the passengers side headlight the drivers side head light goes out. Where should i start to solve this issue. When the drivers side headlight is pluged in by it's self the low beam and the high beam works just find. Any thoughts??
Old Mar 9, 2006 | 11:35 AM
BoulderZ's Avatar
My 2 cents: Sounds like maybe a short associated with the passenger side headlight connection. Clean the plug and connection really well with contact cleaner, and all around the area. If the contacts are really gross and corroded, you can use a little fine-grain sandpaper on the contacts. Then use a little dielectric grease around the seal for the connection, i.e. the edge of the plug. Don't put the dielectric grease on the actual contacts. It's not a conductor.
If there was a lot of corrosion, check around for some likely causes. The 280's overflow bottle is in that area, and the infamous S30 overheating or a careless PO could have caused a bunch of coolant to douse the area. Good idea to check there for rust anyway, it's a known problem area.
good luck,
Dave
Old Mar 10, 2006 | 09:09 AM
brad101010's Avatar
thanks for the pointers, i will try and track it down this week end
Maikel C
Sep 22, 2014 05:20 PM
LVZ280
Dec 8, 2012 10:07 AM
poormandrifting
Dec 3, 2012 09:09 AM
dankfrye@charte
Mar 25, 2011 12:31 PM
