stuck trying to remove rear strut :(
Old Jun 25, 2012 | 04:38 PM
DerekkAllenn's Avatar
Unhappy stuck trying to remove rear strut :(
Hey, removing my rear strut on my 78 280z
It says to remove the spindle in the service manual but i cant get the center bolt out to do that any tips?
does it have a preload point or something cause that ****er wont budge >.<
Old Jun 26, 2012 | 05:39 AM
turbopuppy's Avatar
There is a retaining bolt. After removing the retainer, you have to nudge it back and forth with a drift and a hammer from both sides until you can pull it. Hit it with penetrator and allow to sit for several hours. See
http://atlanticz.ca/zclub/techtips/s...uts/index.html
Have fun and don't let it get to you
Old Jun 27, 2012 | 04:01 PM
theramz's Avatar
I have a present for you...
Are you asking about the stub axle or the spindle pin and lock pin?
Motorsport! Spindle Pin Lock Bolt, 70-78 240Z-260Z-280Z - The Z Store! Nissan-Datsun 240Z-260Z-280Z-280ZX-300ZX(Z31/Z32)-350Z-370Z Parts
Old Jun 27, 2012 | 05:12 PM
its the spindle pin and lock pin im pretty sure.
Old Jun 28, 2012 | 10:04 AM
theramz's Avatar
That taper lock pin is rusted in there. Soak everything with a good penetrant. Back the nut on the lock pin out one turn or just past the threads to protect them from the hammer. Tap it gently to see if it loosens up. Spray it again. I made a spindle pin punch with the threads in the end so I wouldn't destroy it. If you can't do this the parts won't be reusable so buy new ones.
PredatorZ
Mar 18, 2014 11:04 PM
mikeatrpi
Aug 27, 2012 06:59 AM
Photoguy360
Nov 21, 2011 02:22 PM
Comrade_Charlie
Sep 7, 2006 04:51 PM
zpeedrazer
Dec 8, 2001 04:46 PM
