Inexspensive way to lower?
Old Oct 25, 2007 | 07:24 PM
jimp280z's Avatar
I woul like to lower my 75 280. Can I simply cut my coils? Or is there another cheap way to to do it?
Old Oct 25, 2007 | 07:34 PM
Cheap = Crappy. Get a set of Eibach springs.
Old Oct 25, 2007 | 07:52 PM
jimp280z's Avatar
How much? I'm looking for at least 3 inches
Old Oct 25, 2007 | 07:56 PM
uh... 3 inches?! Have you perhaps measured that on the car? You'll bottom out everywhere you go. Please don't say you want to make a "lowrider z." You can get a set of Eibach's for $170-$220. They lower the car about 1.5"
Old Oct 25, 2007 | 07:59 PM
jimp280z's Avatar
well I know that sonds like alot, but I have quite a bit of room. No I don't want to be bouncing around like a town-car but I want to tuck tire. I lowered it on photoshop and they look sweet, ya know?
Old Oct 25, 2007 | 08:01 PM
jimp280z's Avatar
I mean continental. You seen those things bounce around town I'm sure.
Old Oct 25, 2007 | 08:06 PM
dude, 3 inches will rub ur fenders when you turn. 1.5-2 max. cutting will work, but poorly.
Old Oct 25, 2007 | 08:22 PM
entropy31's Avatar
The Cake Is A Lie!
3" is WAY too low. and cutting coils is the ghetto way to do it. your car will ride and handle like a dump truck.
Old Oct 25, 2007 | 08:48 PM
Does Photoshop test drive the car for you these days? I gotta get me the latest version I guess...
Oh... and what do we know anyway, it's not like we OWN Z cars...
Old Oct 25, 2007 | 09:22 PM
jimp280z's Avatar
I'm not saying I don't believe you. I just saying that I have way to much room in my fender wells and I want to change that without spending money I don't have.
Old Oct 25, 2007 | 09:35 PM
Lowering it 3 inches will murder your suspension. The car will have so much camber you won't be able to control it well, and you'll go through tires every 1000 miles or so. If you want it to have a mean / cool stance, get 1.5" lowering springs, and some fatty wheels on the rear w/ fender lips to cover.
Old Oct 25, 2007 | 09:40 PM
entropy31's Avatar
The Cake Is A Lie!
and with that kind of negative camber, you will kill yourself in even a little rain.
Old Oct 25, 2007 | 11:24 PM
chinesekid's Avatar
we all had stock hight before too, i though 1-1.5 inch would still be to high and wouldnt make a difference but it turn out great, it lowers more then you think to the eye
Old Oct 26, 2007 | 12:26 AM
in my z32 with a 2.5" drop and the body kit made the frame sit 2.5 inches off the ground and the body 2 inches. as long as you put stiffer springs in it i dont see a problem with lowering it that much..other then normal alignment issues..
Old Oct 26, 2007 | 05:44 AM
260zturbo's Avatar
Stupid Hurricanes...
cutting springs is a big no no. dont ghetto something bc u dont have money. just save your pennys and get a something name brand. we can tell ya not to but cant stop you.
Old Oct 26, 2007 | 07:19 AM
Spraguepsycho1's Avatar
Another thing to consider is to cut the springs you have to go and pull everything apart to get to the spring (you can't, or at least shouldn't, try cutting a loaded spring). If you need to do all that work, you might as well go the extra mile and put in new stiffer springs, and most likely new stiffer than stock valved struts/shocks since the suspension will have less travel room to do it's job properly.
Old Oct 26, 2007 | 08:11 AM
If you drop the car 2 inches you'll be tucking tire unless you're running some undersized tires right now.
Get some 8 inch wide wheels. Those will fill up the fenders nicely.
Old Oct 31, 2007 | 09:42 PM
jimp280z's Avatar
Right on. I get the message. Thanx
Old Nov 5, 2007 | 07:09 PM
theramz's Avatar
I have a present for you...
You can cut the shock tubes by what ever amount you want to lower it. About mid way on the strut tube below the spring perch. Then you weld an outer sleeve to reinforce it. You will need shorter shocks or they will bottom out and fail. Stock springs have to much travel so you will need bump stops. You will also need camber plates or your car will look like a cartoon mobile. If you get it real low it will look bad *** but will drive like ****. I have Tokico springs and shocks on mine and it is 1" lower with room for at least another 1 1/2" but it is perfect for street. I have an idea in the works to put air bags at least on the front to get it over the driveway. Summit sells parts to make it for about $250. Total cost of a good suspension is about $800-$1000. Do it right or you'll do it over.
Old Nov 5, 2007 | 07:20 PM
Sweets's Avatar
Usedta be Justin260z
dont cut them please. The struts are not designed to operate with a shorter spring that factory. Get a set of Tokico struts with lowering springs off ebay for $350. Save your christmas money.
Old Nov 5, 2007 | 07:41 PM
theramz's Avatar
The Tokicos are about 2 inches shorter than factory springs, in fact you don't need a spring compressor to install them. Cutting the tubes has been an effective way to lower the Z for years.
arsey51
350Z Brakes, Wheels, Suspension and Chassis
Nov 2, 2009 04:11 PM
stefanocassara
Apr 7, 2003 02:06 PM
00Evan
Nov 10, 2002 03:31 PM
miller1986
Oct 15, 2002 12:42 AM
