280 rear in a 260
280 rear in a 260
Hello all. I just purchased a 1974 260z, all stock. Almost, Now I need advice. The previous owner put a mid 80`s 280z rear end in it. Shocks and springs and all, and now it rides like one of those poorly put together muscle cars. You know the ones with the big bad jacked up rear end. I want it to ride lower. I dont want a low riding g car or anything, I wouldn't mind taking it back to stock height or maybe a little lower for the auto cross. Is there anyone out there with suggestions? Can I put the stock springs back under it or am I forever doomed because of the 280z rear?
go get some aftermarket shocks and springs for the 260. illuminas are great if u plan to autocross. and u can get some springs. depending on your budget. the zx weighed alot more then the z's so i bet your ridding high. do u have pics? im curious how it looks. bc if i recall the sleeve on the 240s and early 260s had a small diameter unlike the late 260 and 280s. spring wise they where all different.
It rides really high.
I`ll get some pics tomorrow if I remeber to charge my camera tonight. Do you have a link for those shocks and springs? Also do you think I could get away with just cutting the springs down till I can afford the new shocks and springs?
You are confused new guy! The 280z was only made untill '78. The 280zx was '79-'83. The 280zx rear suspension was a swing arm type rather than the Mcpherson strut of the early cars like you have so there is no way all that is in your car. The coil springs of the '80s car are bigger around so they won't fit either. You might have a '78 rear end and suspension. The late rear coils had a spacer on top that you can remove to lower the rear about 1". Best to show us pics to be sure. You can get the correct springs from a junk yard for now. I can tell you how to get them out real easy.
u will need to either buy or rent spring compressor. (u can get from autozone for 40 bux) u will need to compress the spring b4 u attempt to take the spring out. if u go get a Haynes manual at autozone it will give you detail on HOW TO. u should be able to do it any a couple hrs.
http://atlanticz.ca/zclub/techtips/ read that
ok I`ll read it and buy a manual. I`ll keep you guys posted, and try to update pictures as I go. This is my first ground up resto on an import. Done a 76 camaro and a 69 caprice. Thanks for all your advice.
I checked my 280 stock springs and my 240 with Tokicos and they are at least 2" shorter. You will need to get the correct insolator mount for your car no matter what. They are $63 bucks each so get them from the junk yard. You might as well get the springs there too.
wellm, thats cause they made the 280Z actually rider higher than the 240/260. you can swap the springs i believe actually to lower the 280z. its wierd. but yeah 280's sat higher. and to rent the compressor its 40bucks but if you return them you get ur money back
I have found a local company that can make me coil springs for the rear. Problem Is I need to know what came stock in these. Height, tension load capacity, everything related to those springs. Anyone help me out?
Well folks, Found some stock 260 suspension parts and set about changing them today. Droped the a-arms and everything went without to much fuss. Except the previous owner drove 1/2 lug nuts onto a 12mm lug stud and I may have broke 3 of em on one side. The other side was just fine. Got the parts to fix it on order. I`ll get some pics up soon as Its about to go back together,
borini63
Jun 13, 2015 09:13 AM
81s280zx
Sep 19, 2005 02:42 PM
