Motorsports This board is for Z Racers who compete in Autocross, Road Racing and Time Trials. Focus will be on car set up and modifications. Event coverage, and race parts for sale or trade.
Stainless Braided Lines
Old 02-11-2006, 05:02 PM
Hey Guys Im Just Getting Into Using The Braided Stainless Lines On My Car And Wonder How They Assemble From The Fitting To The Hose. Do You Just Stuff The Hose In The Fitting And Tighten? I Know How To Cut The Hose, Just Dont Want It To Atomize Fuel Everywhere If It Leaks, Then Go Boom.
SHADY280 is offline
Old 02-12-2006, 11:10 AM
tube80z's Avatar
Go to Earl's or any of the other sites. They all have intructions on how to put together the hose. I have yet to have any AN hose/fittings leak after putting them together. I can't say that for flared tubing.
Cary
tube80z is offline
Old 02-12-2006, 01:43 PM
Thanks I Found It, Ive Done Solid Tubing Before, If You Have The 37 Deg. Flare Tool And A Bender It Isnt That Bad
SHADY280 is offline
Old 02-12-2006, 03:38 PM
tube80z's Avatar
Sorry, I should have said double flare, as in stock. My new car will have AN hardline too.
Cary
tube80z is offline
Old 02-14-2006, 03:16 PM
Spudz's Avatar
Cary,
Are you planning on running aluminum AN tubing for the fuel or braided line?
I am redoing the plumbing on the Roadster, and I am still trying to plan things out before I cut
Mike
Spudz is offline
Old 02-14-2006, 07:06 PM
Measure Twice Before You Cut!!
SHADY280 is offline
Old 02-15-2006, 08:23 AM
tube80z's Avatar
I'm going to use steel line with braided only at the ends. A number of hotrod companies offer brake line kits that use AN flares/fittings. That's what I'm using along with a few pre-made AN braided lines. I don't know how they do it but pre-made lines are cheaper than I can buy the ends for.
When you do the masters/pedal box make sure to do braided for the first little bit. This makes changing masters much easier
Cary
tube80z is offline
E_Rock
04-26-2011 06:02 AM
FricFrac
03-17-2011 11:21 PM
FCPImport
02-02-2011 11:09 AM
BRAAP
05-06-2005 05:37 PM
Rbolz
06-05-2003 05:59 PM
Quick Reply: Stainless Braided Lines
