Stainless Braided Lines
Hey Guys Im Just Getting Into Using The Braided Stainless Lines On My Car And Wonder How They Assemble From The Fitting To The Hose. Do You Just Stuff The Hose In The Fitting And Tighten? I Know How To Cut The Hose, Just Dont Want It To Atomize Fuel Everywhere If It Leaks, Then Go Boom.
Cary |
Thanks I Found It, Ive Done Solid Tubing Before, If You Have The 37 Deg. Flare Tool And A Bender It Isnt That Bad
Cary |
Cary,
Are you planning on running aluminum AN tubing for the fuel or braided line? I am redoing the plumbing on the Roadster, and I am still trying to plan things out before I cut :) Mike |
Measure Twice Before You Cut!!
When you do the masters/pedal box make sure to do braided for the first little bit. This makes changing masters much easier Cary |
