T5 swap
Old 04-02-2006, 04:14 PM
Whitesmoke's Avatar
T5 swap
I'm new to these cars. I have a T5 out of a mustang sitting in my garage. Is it possable to put a bell housing from a T5 out of a turbo on to it and then put it in a 79 NA 2+2? thanks for the help
and if not what would it take to make the T5 from a turbo fit? just bolt it on? i just figured since i have this one here and the tranny in the car now wont go into reverse this was the best option
Whitesmoke
Whitesmoke is offline
Old 04-02-2006, 04:27 PM
I personally haven't heard of anyone using the mustang T5... but if the bell housing mounts up & the input splines are the same... it should work.
A lot of people (including myself) have swapped the n/a tranny to a T5. Just requires the T5 driveshaft & diff coupler. Simple to do. There are a lot of threads on here that talk about the swap too, so feel free to use the search button. And welcome to ZDriver.
NismoPick is offline
Old 04-02-2006, 04:31 PM
Whitesmoke's Avatar
yeah i used the search but T5 is only 2 letters so it didnt pick it up and i was overwhelmed with pages upon pages of motor swaps lol
thanks for the info though
Old 04-02-2006, 04:49 PM
jfairladyz's Avatar
Things that need to match up:
1) Input spline count
2) Input shaft diameter
3) Input shaft length
4) Bolt pattern for Bell housing to tranny mouting
You'll need a custom driveshaft as well. Like Nismo said, the NA and turbo shafts are not the same.
I think I recall someone on here saying the T5 out of a late model V6 Mutang would fit up. But I cant remember for sure.
jfairladyz is offline
Old 04-02-2006, 10:07 PM
T5 came outa a 5.0 mustang, there are alot of the mrolling through ebay right now to.
hoov100 is offline
Old 04-02-2006, 10:28 PM
The T5 also came in the SVO 4cylinder Mustang:
But he said he already has the T5....
Old 04-02-2006, 10:38 PM
the T5 came out with two different splined input shafts, one regular, one fined. if i remember correctly, we have the fined one.
http://cgi.ebay.com/ebaymotors/TREME...51677780QQrdZ1
hoov100 is offline
Old 04-02-2006, 10:52 PM
Whitesmoke's Avatar
i think im just going to hit up the junkyard for a turbo T5. i really want the T5 instead of rebuilding the one i have in it because then i can get a short throw sifter as well.
also the T5 was in all manual tranny mustangs since 84-98 then they went to the tremmic 3550 with the 99-04 body and that link you posted is not a T5 its a TKO. my motor is not making 600ft.lbs. lol
Old 04-03-2006, 10:18 AM
lww
Head Muckraker
lww's Avatar
Check the gearing on the Mustang T5. They were different depending on what year and your 280ZX will be a pig if you get a T5 with a tall 1st gear.
Also, you'll need a custom drive-shaft.
lww is offline
Old 04-03-2006, 11:33 AM
jfairladyz's Avatar
I used to have one of those SVO Mustangs. It was fun til it blew up That was one of my first cars
ZXT83
04-15-2012 06:35 AM
DeathByNissan55
23
03-26-2012 10:26 PM
ZeeBest
08-07-2011 08:36 PM
PEARL_300ZX
17
01-03-2008 05:39 PM
pete8717
04-01-2006 07:22 PM
Quick Reply: T5 swap
