Polyurethane subframe bushings? maybe...
Old Aug 30, 2006 | 04:36 PM
bpealer's Avatar
Has anyone else done anything about the subframe bushings on their zx? It seems like the only solution is to buy stock rubber or do like Jeff P did and make some solid aluminum ones. I'm not sure how much the solid ones would cost me and theres no way i'm going through all the work of tearing apart my rear suspension just for stock rubber. So, I ordered a set of prothane subframe bushings for a z31 because they are pretty close in size, for only 36 bux. They only need to be trimmed a little bit in diameter. Seems drastic, but I called MSA and they said they won't have the 280zx kit for awhile.
My bushings were so bad out back that I couldn't even drive my car anymore. The caster would change so much when the suspension compressed that i'd be sliding all over the place. Hopefully i'll have some pics so you guys can see what i'm talking about.
So have any of you guys done anything similar? This just seems like the easiest method right now, till someone makes the right kit.
Old Aug 30, 2006 | 10:26 PM
never thought of using the 300zx ones, good idea, its almost the same, so its gotta work. your the pioneer here so let use know. i was gonna weld mine up solid, but i think that may be a bad idea, i already solid mounted my differential, it made no real difference, not even in sound. go figure
Old Aug 31, 2006 | 07:06 AM
runningjalapeno's Avatar
What is MSA ?
Old Aug 31, 2006 | 07:15 AM
z-hag's Avatar
Queen of Yachts
MSA is parts for our babies, people who love z's of all kinds--even the bubble-butt newer ones, and events, etc. should be a link somewhere....
Old Aug 31, 2006 | 09:50 AM
skittle's Avatar
Taste My Rainbow
http://www.thezstore.com/store/merchant.mvc?Screen=SFNT
Old Sep 5, 2006 | 07:55 AM
bpealer's Avatar
alright, got em in...
long hours at work over the weekend kept me from getting this done earlier, but I finished getting them in last night. Ah, the difference is amazing. The rear suspension is a lot tighter.
New bushings out of the box.
Bushings with a little luvin' from the die grinder.
Old bushings being cut out.
Out with the old and squishy...
In with the new.
The subframe cleaned and painted semi flat black. I was going to powdercoat it, but I had less time than money right now.
Next week I have to put in the rear poly control arm bushings when I do the rear wheel bearings.
Old Sep 5, 2006 | 08:21 AM
Sweet bro! So those are the Z31 bushings? They fit snug?
Old Sep 5, 2006 | 08:26 AM
bpealer's Avatar
Yeah, they're snug. Its pretty much "cut-to-fit." The z31 bushings were a bit bigger in diameter so I just trimmed away a little each time till they fit tight. These seem to have made as much of a difference as the springs and struts.
ivyleague
Oct 20, 2014 09:12 AM
Rupe
Jul 3, 2012 08:00 PM
veyenyl
Feb 17, 2012 09:51 AM
Mrmoose
FS: 300ZX (90-96)
Feb 20, 2011 09:27 PM
mewfis138
Jun 11, 2005 08:34 PM
