Body work
Old 03-07-2017, 06:40 AM
  #101
I have a present for you...
theramz's Avatar
turn signals
These just in. I want them to match the smoke rear taillights so I got some film to try. If I don't like it I'll get some clear smoke paint from ebay.
Maybe just paint the buckets black or gray.
theramz is offline
Old 03-07-2017, 08:49 AM
  #102
beg3yrs's Avatar
Originally Posted by theramz
Yeah, he's not as distracting as those other helpers.
I decided to upgrade the rear suspension with the parts I got from a '73.
The rear dif hanger, mustache bar and sway bar. The earlier cars had the dif farther forward about an inch and no sway bar. I also was saving an R200 with 3.9 gears. I think I'll have it all blasted and powder coated.
Ah yes, those other helpers....
Your car is clearly going to be awesome. All the progress is pretty cool...
beg3yrs is offline
Old 03-13-2017, 09:36 AM
  #103
theramz's Avatar
The best way to get the old bushings out is to burn them to death. The inner sleeve on the A arms needs to be cut through so it can be punched out.
Attached Thumbnails Body work-bushing-removal3.jpg   Body work-bushing-removal2.jpg   Body work-bushing-removal1.jpg
theramz is offline
Old 03-13-2017, 09:53 AM
  #104
Skully's Avatar
Excellent! Whats your plans paint or powder-coat all the suspension parts?
Skully is offline
Old 03-13-2017, 10:36 AM
  #105
theramz's Avatar
I'll have them sand blasted and powder coated. The rear sway bar and brackets are not OEM. The Datsun bar brackets are mounted to the frame rails. The '70-'71 did not come with it.
I decided to use the R200 VLSD in this car. The R180 is shown here next to the R200. Far right is the VLSD/3.9 ratio out of the M30. The brackets from a 280z with R200 need to be used. I don't have the later mustache bar so I will have to re-drill it and might have to reshape the curves.
The diff yoke needs to be swapped or re-machined to fit the drive shaft. Also the axle shafts. They just pry out.
Attached Thumbnails Body work-r200-swap3.jpg   Body work-r200-swap2.jpg   Body work-r200-swap.jpg   Body work-r200-swap5.jpg   Body work-r200-swap6.jpg
theramz is offline
Old 03-15-2017, 08:04 PM
  #106
theramz's Avatar
I needed to bore out the flange to accept the larger hub on the '71 driveshaft and drill the bolt pattern to match. The mustache bar had to be drilled out with an end mill because it is only a little bit bigger diameter and slightly wider. A drill would not work good for this.
The alternative would be to get a bar and pinion flange from a later 5 speed car that has the R200 diff and the mustache bar with the hangers. A very easy bolt on.
Attached Thumbnails Body work-wp_20170313_12_16_13_pro-1-.jpg   Body work-wp_20170315_11_49_18_pro.jpg
theramz is offline
Old 03-15-2017, 10:43 PM
  #107
beg3yrs's Avatar
We know about all your hot helpers but your toys/tools are pretty awesome too.
beg3yrs is offline
Old 03-19-2017, 07:29 PM
  #108
theramz's Avatar
That's what they said. Sorry, can't resist a straight line like that.
Did the mock up of the R200 swap to make sure of the fit. Looks good so I think I will just paint it all and get it in.
theramz is offline
Old 04-22-2017, 07:54 PM
  #109
theramz's Avatar
Got the diff in, drive shaft, new axle bearings, seals. The R200 went in without the later hangers being necessary. The drive shaft was almost to short. The later drive shafts are even longer. The new spindle pin bushings were too long so had to grind about 1/16" off the flange ends. They fit really tight so it was easier to put the spindle pin in and lock it down then the outer bushings. It can be difficult with one person so I put everything together after I hung the struts. The drive shaft needed new u-joints
Attached Thumbnails Body work-arm.jpg   Body work-bearing-puller.jpg   Body work-d-shaft.jpg   Body work-outer-bearing-install.jpg   Body work-bearin-install.jpg
theramz is offline
Old 04-24-2017, 04:06 PM
  #110
beg3yrs's Avatar
Great progress Tom. I enjoyed the photos.
IIRC I had similar issues with the spindle pin bushings and I ended up using a Dremel tool to get them to fit. These were poly bushings from Energy Suspension.
beg3yrs is offline
Old 05-01-2017, 09:47 AM
  #111
theramz's Avatar
Grandson and me got it back on the ground. Rear suspension and disc brake conversion complete. Ride height is exactly where I wanted it. Going to sand off all the paint and then spray epoxy primer sealer while the weather holds up. Haven't decided on color yet. Maybe a carbon fiber wrap.
Attached Thumbnails Body work-rear-disc-conversion-mounted.jpg   Body work-rear-disc-finished.jpg   Body work-ride-height.jpg
theramz is offline
Old 05-06-2017, 06:17 PM
  #112
theramz's Avatar
So while the bad girl was outside, (yes Scott,Skully, the metal one) I started removing all the old paint. Cut the glass molding back and taped the glass to protect from the sander. Plan is to have flush molding for a sleeker look. I'll leave it in place to keep the dust out. Back inside in time for 1/4" of rain today.
Attached Thumbnails Body work-sanding1.jpg   Body work-sanding2.jpg   Body work-sanding3.jpg
theramz is offline
Old 05-08-2017, 10:21 AM
  #113
beg3yrs's Avatar
Hey it's looking good Tom. I think that flush windshield will look great! I should have thought about that when doing mine.
Here's a different kind of metal bad girl for you.
beg3yrs is offline
Old 05-08-2017, 12:21 PM
  #114
theramz's Avatar
Still raining so I went back to body working. Not the heavenly type.
Filler on the left and rear. Finished welding the right. Added some weld beads for the filler on corner for the small dent from the bumper strike. Better than pulling the gas tank. No evidence of collision damage any where on the car.
Attached Thumbnails Body work-b-work-1.jpg   Body work-b-work-2.jpg   Body work-b-work-3.jpg
theramz is offline
Old 05-09-2017, 05:49 AM
  #115
theramz's Avatar
Sanded and another coat. First the metalized filler, sand and finish coat. Forgot to take a pic of the welds ground smooth. Careful welding still caused some warpage that I had to bump out. I think next time I will try panel adhesive.
theramz is offline
Old 05-09-2017, 05:55 AM
  #116
theramz's Avatar
You can't spank that kind Scott
theramz is offline
Old 05-10-2017, 05:31 AM
  #117
theramz's Avatar
This spoiler is off a 90's Firebird. Going to shorten it by 8" and make brackets. The contour is perfect shape for what I want.
theramz is offline
Old 05-10-2017, 09:23 AM
  #118
beg3yrs's Avatar
This car is going to be awesome.
beg3yrs is offline
Old 05-11-2017, 09:12 AM
  #119
theramz's Avatar
Spoiler mock up. Now for the brackets. Then carbon fiber wrap.
Attached Thumbnails Body work-spoiler-2.jpg   Body work-spoiler-3.jpg   Body work-spoiler-4.jpg   Body work-spoiler-5.jpg
theramz is offline
Old 06-08-2017, 07:35 PM
  #120
theramz's Avatar
Back at it. Some real fab work. Had the skins cut on the water jet. Made the top and bottom brackets out of 3/16 stainless. Had to wrap the sheet metal around them. Started with the radius and gradually welded around the bracket just tacking it in place. tacked in the other one and stitched it up. Took them to work and smoothed out the welds. Got some panel weld adhesive to glue everything down and bolt on the car to test fit. Ordered some carbon fiber wrap.
Attached Thumbnails Body work-wing-1.jpg   Body work-wing-2.jpg   Body work-wing-3.jpg   Body work-wing-4.jpg   Body work-wing-5.jpg
Body work-wing-6.jpg   Body work-wing-7.jpg   Body work-wing-8.jpg   Body work-wing-10.jpg   Body work-wing-11.jpg
theramz is offline
Old 06-10-2017, 09:47 PM
  #121
beg3yrs's Avatar
Amazing work Tom.
beg3yrs is offline
Old 06-11-2017, 03:21 PM
  #122
theramz's Avatar
Just about done. Drilled the mount holes. Used scrap for reinforcement. Panel adhesive and wait.
Attached Thumbnails Body work-wing-13.jpg   Body work-wing-14.jpg   Body work-wing-15.jpg   Body work-wing-16.jpg   Body work-wing-17.jpg
theramz is offline
Old 06-30-2017, 08:41 PM
  #123
theramz's Avatar
A little more work with metalized filler with my 10 year old grandson. Learns fast.
Another natural! A little finish filler then the cf wrap comes next week.
Attached Thumbnails Body work-wp_20170629_20_29_06_pro.jpg   Body work-wp_20170629_20_28_52_pro.jpg   Body work-wp_20170629_13_42_23_pro.jpg   Body work-wp_20170629_12_47_33_pro.jpg
theramz is offline
Old 07-09-2017, 12:20 PM
  #124
theramz's Avatar
Finished up the filler and primered the wing. Wrapped it with carbon fiber vinyl from Vivvid. Had a piece of scrap to try on the roof to see how it would looked wrapped around the drip rail. I like it.
Attached Thumbnails Body work-wp_20170709_11_11_02_pro.jpg   Body work-wp_20170709_11_11_08_pro.jpg   Body work-wp_20170709_11_23_53_pro.jpg   Body work-wp_20170709_11_39_24_pro.jpg   Body work-wp_20170708_15_53_03_pro.jpg
theramz is offline
Old 07-09-2017, 12:39 PM
  #125
Skully's Avatar
Very nice! I was thinking really really hard about doing a color change with a wrap too, how is the stuff to work with?
Skully is offline
Quick Reply: Body work
