Hit the dyno
Old May 3, 2007 | 01:16 PM
i8acobra's Avatar
Hit the dyno
Well, I got my car on the dyno yesterday and had my roommate do some tuning. First, gotta do the credits... Tuning done by Jeremy Wolf. Dyno was a Mustang dyno provided by Doug at Doug's Dynopower (The DSM Specialist) in Henderson NV. Now, on to the numbers. First chart is before and after in 4th gear. Tuning was done in 4th gear to avoid running at 140mph+ on the dyno. Tuning was done on a Mustang eddy-current dyno, which is a load-based dyno. Power mods on the car are:
AEM CAI
APS plenum
UR pulleys
DC Sports headers
Ultimate Racing cats
Borla cat-back
Turbo XS UTEC
First, I'd like to preface by saying that this is an '06 with the Rev-Up motor. I don't have any experience with the UTEC prior to now, so I don't know if this is a common problem, but the ECU seemed to be fighting the UTEC. Just when we thought the A:F ratio was good, a new lean spike would appear somewhere else. We also couldn't get the ECU to accept the timing as programmed. It's possible the ECU was cutting back the timing due to high IAT's. Ambient was 92 degrees. The UTEC is also very sensitive to minor changes. Many of the changes to the fuel trims were made in 0.1% increments. I'm going to get the UTEC MAP sensor in the next week or so and see if it's any easier to tune in Speed-Density mode.
As you can see, power went from 249 to 263 and peak TQ actually dropped from 231 to 229. TQ was increased consistently above 5200rpm though.
This graph is 5th gear, before and after tuning:
This is my "internet *****" best 5th gear pull (281HP 237TQ):
Next step is to install the JWT clutch and flywheel. Then I'll get the MAP sensor and map selector switch, install them and get re-tuned.
Old May 3, 2007 | 01:24 PM
ViViD's Avatar
Very nice....cant wait to see the results post clutch and flywheel install.
Old May 3, 2007 | 02:09 PM
i8acobra's Avatar
They're going in on Tuesday. I'm ordering the map switch and MAP sensor today, I hope.
Old May 3, 2007 | 02:42 PM
i8acobra's Avatar
Originally Posted by showtypeZ
Oops...I was supposed to dyno at Doug's last night and COMPLETELY forgot.
We were wondering where you were. We were looking forward to comparing the cars.
Old May 3, 2007 | 03:21 PM
terrasmak's Avatar
What was the baseline , or did you not Dyno that originally.
Old May 3, 2007 | 03:26 PM
Stealth's Avatar
Nice #. Whats the timming,Coolant temp and Weather temp?
How much you spend? I ask you this because i want to compare with EVO, who get best bang for the buck.
Old May 3, 2007 | 03:52 PM
i8acobra's Avatar
My bad... had the wrong first dyno chart up there. The baseline was 249HP in 4th and 277hp in 5th. I don't have a stock baseline. My baseline is with the parts installed, but not tuned.
Timing was around 24 to 27 degrees total. UTEC is set for 29, but the ECU was pulling timing due to high IAT's. Coolant was at 77-78 C (171-173 F) and ambient was 92-94 degrees F.
I have about $3200 in power parts and about $700 in cooling system parts. The rest is all looks and audio. Bang-for-the-buck, factory FI cars will always win that. $3200 in an EVO should get you close to 400whp.
Old May 3, 2007 | 04:51 PM
702Fairlady's Avatar
How much was it to hop on the dyno. I'm tihnkin about going next week to see what I'm putting down with all my mods and such.
Old May 3, 2007 | 05:20 PM
i8acobra's Avatar
$65 for 3 pulls with a:f. I paid for two hours.
Old May 4, 2007 | 07:39 AM
i8acobra's Avatar
Too bad you didn't have my phone number cuz I was just chilling out at home. 355-8406 Now you have it. Yeah, I'm going to have to reschedule it for next week. I've been so busy lately. GF is moving in with me so I'm trying to get my house situated for that.
I'll be going back there soon. I get my clutch/flywheel installed tuesday and I'm getting a MAP sensor so I can switch to speed-density tuning.
Old May 4, 2007 | 08:47 AM
ViViD's Avatar
well hit me up and I'll go down there with you. you can tell doug that too. just give me a call or let me know on here when you wanna go. maybe we can set up a 350z dyno day and get a discount. Blaine, your Z may be too low to get on the dyno unless you stick some wood boards under the tires creating a small ramp.
I would love to dyno it....but my car always seem to be the problem child with clearance issues =( . So if we can get it on safely then great but if not no biggie...regardless that sounds like a good event so i will go either way.
Old May 4, 2007 | 10:41 AM
If you sit any lower than I do then it is going to be hard. It took a guy almost 15 minutes to get my car onto a lift yesterday. There goes my plans of putting on some S-Techs.
Old May 4, 2007 | 10:50 AM
vegaseric's Avatar
...maybe we can set up a 350z dyno day and get a discount. ...
+1 on the dyno day. i need to get a baseline before i start throwing some mods at the G.
Old May 11, 2007 | 09:29 AM
i8acobra's Avatar
Installed my clutch, flywheel and clutch line yesterday. With a friends's help (and his lift) we knocked it out in a little less than 4 hours. Also, got my map selector, MAP sensor and AEM wideband yesterday. I'll be installing those on Saturday.
Old May 11, 2007 | 03:27 PM
ViViD's Avatar
Cant wait to hear it now.
i8acobra
May 14, 2007 05:12 PM
Nforce1
Oct 24, 2005 04:27 PM
K Cuv
Oct 18, 2005 01:54 PM
SinCity350Z
Sep 23, 2005 08:55 PM
PowerhungryBill
May 4, 2005 09:56 AM
