Aluminum block Vs. Iron block.
Old Mar 17, 2007 | 04:04 AM
Stealth's Avatar
Thumbs up Aluminum block Vs. Iron block.
The answer is TENSILITY and HEAT!!! like i told you guys before.
That's why EVO X will better than any EVO from the engine to suspension because better technology, materials, research and development.
Pound for pound, aluminum is four times stronger than steel. It has greater tensility (the greatest longitudinal stress a substance can bear without tearing apart) and yield (how much stress a material can tolerate before permanently deforming).
Apparently in a crash, aluminum absorbs two times the energy compared to steel.
Aluminum can replace iron and steel in automobiles with weight savings of 45 to 50 percent with increasing performance and no safety loss.
http://www.aluminum.org/ANTemplate.c...ContentID=9015 <<<<<<<Link
http://www.autoaluminum.org/main/ind...0&ArticleID=20
http://www.streetrodderweb.com/tech/...aluminum_axle/
Old Mar 17, 2007 | 07:28 AM
y2daniel1981's Avatar
well even I knew that...
Old Mar 17, 2007 | 08:07 AM
i8acobra's Avatar
I'm going to have to disagree. Pound for pound, aluminum is better than iron. However, an iron block has many more pounds of material than an aluminum block. To make an aluminum block as strong as an iron block it need to be much larger with greater bore spacing. In the case of the EVO X, not only did they switch to an aluminum block, but the also went to an open-deck design whereas the old 4G63 was a closed deck. The new EVO will be a better car in stock form than the EVO IX, but it won't take to mods as easily. Like the Honda motors, in order to make big power numbers, the block is going to have to be resleeved with ductile iron sleeves.
Lanoi
Jun 18, 2010 02:46 PM
CWHammer
Mar 24, 2008 06:56 AM
Carl's Z
Jan 15, 2007 09:09 PM
AV240Z
Apr 28, 2003 05:04 PM
280steveX
Apr 9, 2003 06:34 AM
