Suspension Investment
Next question....
How much have spent to improve the way your car handles? |
i need to get that reciept from you...i keep forgetting to get my dads fax number from him
SZ subframe spacers shocks and springs came with the car but havent been installed 91...where are your lists? id like to know what all you have now |
KYB AGX adjustable shocks
Eibach Springs Suspension Techniques sway bars more to come..... |
It is stock right now, but I want to get Eibach springs, with KYB struts in the near future. :) I am just going to swap them out of my '81 for now, because my '82's rear end is pretty much shot. It don't have much, cushion in the back. And it rides rough down the road. :( Of course the '81 is not perfect, but it did ride better, than the '82 I am currently restoring. :D
KYB AGX Shocks
Eibach Sprints Suspension Techniques front & rear sway bars Sub Frane spacers Carbing front & rear strut bars Powertrix tension rods Powertrix front camber arms Powertrix rear camber arms Powertric rear toe arm Powertrix rear traction arms |
well i was luky mine has all been done befor i got the car. but it is sweet
Sorry...here it is
Tokico Illumina shocks Eibach Pro Springs SPL adj. tension rods SPL adj. upper arms (f&r) SPL subframe spacers Stillen sway bars (f&r) SPL solid endlinks for sway bars Carbing strut bars (f&r) Skyline brake kit + goodridge braided lines SPL master cylinder brace BBS RC wheels 17x8.5 fr/18x9.5 rear w/Michelin PS 255/40 f & 275/35 r (imo...more traction is worth the tradeoff for the heavier setup) still to come in the future.... SPL adjustable lower arms SPL HICAS eliminator...they're working on a new setup that encorporates the traction rods from the TT and toe arms from the N/A. AMZ ladder bar |
1 Attachment(s)
Let's see what all I can remember...
KYB Struts all around Eibach lowering springs Urethane bushings New tie rods/ends New Ball Joints New Idler Arm/Link Assembly Bump steer spacers Upgraded sway bars front/rear Upgraded Brake Calipers front/rear Performance brake pads front/rear Slotted rotors front/rear New master cylinder and Booster Steel braided lines (all) New wheel bearings (all) Custom Billet adaptors to fit 17" 4x100 wheels (car came with 14"s) Ten spoke "Riax" 17" wheels with gun metal spokes and polished outer lip. 235/40ZR17 Falken GRB FK-451 tires And a whole bunch of little miscalaneous stuff I'm probably forgetting right now. I try not to think too much about how much has gone into this car so far... :eek: Rod. |
well i havent got all of the actuel part names but.
Eibach Pro Springs adj. tension rods Stillen sway bars (f&r) adj. upper arms (f&r) not to sure how to work them but i will figuer it out subframe spacers strut bars (f&r) not shure who makes them solid endlinks for sway bars Upgraded Brake 4 piston Calipers in front they are breamo with 16 inch vented cross driled and sloted(i dont know why the rear was done but it is still stock steal braded brak lines front and rear Stillen HICAS eliminator adjustable lower arms 5 way ajustibel shoks Urethane bushings now im not too sure on all of it but there is a lot of shit on my new z. it is over welming |
Tokiko struts Bump steer spacers, I made them myself F&R upper strut bars '85 front sway bar, made the adaptors rear sway bar, early Z all new urethane bushings new rod ends new condition rack from a '75 Toyota S-13 calipers on front with '84 ZX vented rotors, I made the rotor adaptors '79 ZX rear disc conversion. I made the brackets 17" Revo wheels with Toyo Proxies. I made the adaptors. Rear diff mount snubber, home made. Corners like a go kart now, way more fun! |
