help eclipse throttle--rpm to high
:eek: i need help with my throttle and gas pedal idk whats wrong with it the gas pedal is hard to push down..and the throttle body only goes up only half way and wont open all the way...have already messed with the throttle cables but idk still gfets stuck and runs to 6000rpm and stays..need help asap thnxs in advance
maybe a good cleaning of the throttle body and all the associated parts is in order.
Could be the throttle cable sticking in the sleeve. Disconnect the throttle cable from the TB's. If the TB's are easy to open by hand, then it's the cable.
thnXs..yea i went yesterday to the junk yard and got better cables that slide easier but when i push down on the gas pedal it only opens the throttle body half way...
